ltranny swap question
Old Jan 30, 2007 | 03:36 PM
zenon8890's Avatar
Default ltranny swap question
will a tranny from a d15b carburated 90 4door civic fit my d15b vtec 88 crx?!
Old Jan 30, 2007 | 03:37 PM
dr_latino999's Avatar
Default Re: ltranny swap question (zenon8890)
Jordan...nice place.
It should but following the rules of EF'dom the 1990 transmission would have a different input shaft than the 1988 so you'd have to change the clutch to match.
Old Jan 30, 2007 | 03:39 PM
SOHCinWA's Avatar
D trannis will bolt up. Yes the 88 has more splines (2) than 89& up. So you would have to get another disc for the 90 tranny
Old Jan 30, 2007 | 03:44 PM
zenon8890's Avatar
thanks guys, cuz my tranny is fucked up, it doesnt grind and shifts smoothly, but the passenger side wheel spins unbelivably than the driver's side, i change my tranny once and i changed the clutch and the axels cuz they didnt fit my old, so i guesss that my tranny now is 90, but i want a longer gears so i guess the carborated engine comes with longer gears than the si, i'm having unbelievable burn out problems with this tranny cuz its too short.
Old Jan 30, 2007 | 04:07 PM
h224thgensedan's Avatar
get the flywheel as well.
The 88 flywheel is 190mm and the 89 is 200mm
Old Jan 30, 2007 | 04:13 PM
Default Re: (zenon8890)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCinWA &raquo;</TD></TR><TR><TD CLASS="quote">D trannis will bolt up. Yes the 88 has more splines (2) than 89& </TD></TR></TABLE> One more spline.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zenon8890 &raquo;</TD></TR><TR><TD CLASS="quote">i'm having unbelievable burn out problems with this tranny cuz its too short.</TD></TR></TABLE> You do realize that we have 100#s of torque, right? Don't dump the clutch like it's on fire and you'll be fine.
jdmb20boi
11
Jun 12, 2008 09:27 PM
hatchinprogress
12
May 28, 2005 12:00 AM
LoooseGSR
10
Nov 27, 2003 08:50 PM
94sisol
Sep 28, 2003 06:13 PM
WhiteLightening
Jul 24, 2003 10:29 PM
