good cams and cam gears for a b16a2
Old Jan 30, 2007 | 01:15 PM
rdwaldo's Avatar
Default good cams and cam gears for a b16a2
i am getting cams and cam gears and wanted to know some good brands and why they are better
Old Jan 30, 2007 | 01:20 PM
DonF's Avatar
Default Re: good cams and cam gears for a b16a2 (rdwaldo)
Spoon or JUN. Because they cost more.
Old Jan 30, 2007 | 02:39 PM
Furyof4's Avatar
Default Re: good cams and cam gears for a b16a2 (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Spoon or JUN. Because they cost more.</TD></TR></TABLE>
JDM=better
Old Jan 30, 2007 | 03:05 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: good cams and cam gears for a b16a2 (Furyof4)
True story.
I use pure Carbon fiber cams myself and frees up a good deal of losses from the lighter weight.
They were made by Mugen, by hand.
Old Jan 30, 2007 | 03:27 PM
Grand's Avatar
Default Re: good cams and cam gears for a b16a2 (Max The Amazing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Max The Amazing &raquo;</TD></TR><TR><TD CLASS="quote">
True story.
They were made by Mugen, by hand.</TD></TR></TABLE>
Those look pimp if you do'nt use a valve cover too
Old Jan 30, 2007 | 05:02 PM
UncleD's Avatar
Default Re: good cams and cam gears for a b16a2 (LG_R32)
Is this for a stockish B16? If so, I would suggest some type r cams with your stock gears. Can I ask what your budget is and if you can do any of the work yourself? Any access to a local dyno maybe??
Old Jan 30, 2007 | 05:53 PM
rdwaldo's Avatar
Default Re: good cams and cam gears for a b16a2 (clean rice)
i am looking to spend around 500 on cams, the motor is close to stock now, h/i/e, crank pulley, clutch and flywheel, but i am doing a full port and polish at the beg. of summer but i am getting parts now.
Old Jan 30, 2007 | 06:22 PM
UncleD's Avatar
I would do type r cams for now man, if you were to do anything larger I would highly reccommend valvetrain and thats goiong to put you above the 500 mark unless you buy something used. And instead of porting your head, I would look into buying a ls or B20 block and doing a ls/vtec. You can build a very reliable block for around the same price it would cost you for a good head job, and make more power with it too.
Old Jan 30, 2007 | 07:07 PM
rdwaldo's Avatar
well i will be getting a new valve train and spring and retainers when i get the port done. i didnt mean all together i wanted to spend 500, i was just thinking around 500 just for the cams. So you think i should do a new block instead of the port and polish? Would the b16 head even mount to a b20 or ls/vtec?
401tuner
15
Sep 7, 2007 01:30 PM
B18C-YA!
Apr 4, 2006 04:06 PM
ghg78
Nov 5, 2005 09:40 AM
DXK Eg
Jun 14, 2005 08:21 AM
EK MONEY
14
Nov 13, 2003 04:05 PM
