TPS ???
Old Jan 30, 2007 | 11:48 AM
team 15's Avatar
Default TPS ???
My brother have a 97 civic ex that has a check engine light. The code is 7 which is the tps sensor. So i took the tps out of the throttle body. The gasket from the tps is torn. Could it be the gasket or could it still be the tps sensor?
Old Jan 30, 2007 | 12:23 PM
Relic1's Avatar
the TPS supplies a voltage to the ECU via turning the sensor. the gasket has nothing to do with the reading or the CEL.
be sure to replace the gasket.
Old Jan 30, 2007 | 12:37 PM
Jimmy's Avatar
Global Moderator
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">the TPS supplies a voltage to the ECU via turning the sensor. the gasket has nothing to do with the reading or the CEL.
be sure to replace the gasket.</TD></TR></TABLE>
Yeah and now your gonna haft to adjust the TPS.
bdr_one
May 9, 2015 10:02 AM
WalkerGSR1
Nov 7, 2006 01:41 PM
JDMCivicEF9
May 7, 2005 10:47 PM
