Post your Pro 2 cam setups , specs etc
Old Jan 30, 2007 | 11:22 AM
ATS*Mark's Avatar
OG triple OG
Default Post your Pro 2 cam setups , specs etc
i know there have been alot of threads on the pro2's but i would like to see setups , what your cam gear settings are and what u did to get them to idle nice. and dyno charts are a plus too
just put the pro2's in after breaking the motor in. and we are going to tune soon i wanna have all my ducks in the right pond. here is my setup:
85mm 12:1 bottom end
portflow p73 head with supertech valve train and pro2 cams
hytech production header
twm 52mm itb's
going to tune on crome pro
what problems did u guys experience in getting these things to run right and how did u over come them?
Old Jan 30, 2007 | 02:38 PM
92TypeR's Avatar
FSAE
Default Re: Post your Pro 2 cam setups , specs etc (ATS*Mark)
85x87.2
12:1
ITR head (no portwork) w/SuperTech valves and springs/retainers
Stock ITR IM/TB
Password JDM whale *****
Comptech Race 4-2-1
T1R 70mm
Tuned on Crome Pro
Cam Gears @ +4e/+1i
218/151 SAE - DynoJet 248c
Warms up and idles like stock.
Did a brief writeup on idle procedures: Here
Modified by 92TypeR at 4:29 PM 1/30/2007
Old Jan 30, 2007 | 02:58 PM
MR_Ek4's Avatar
Default Re: Post your Pro 2 cam setups , specs etc (92TypeR)
What are your gears set at ? ?
Old Jan 30, 2007 | 03:21 PM
Grand's Avatar
Default Re: Post your Pro 2 cam setups , specs etc (EM1_00MRBuilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1_00MRBuilt &raquo;</TD></TR><TR><TD CLASS="quote">What are your gears set at ? ?</TD></TR></TABLE>
Degree your cams. Do'nt worry too much about other's cam gear setting's they will not help you any.
Old Jan 30, 2007 | 05:22 PM
UncleD's Avatar
Default Re: Post your Pro 2 cam setups , specs etc (LG_R32)
I'm super curious to see what you make holmes
Old Jan 30, 2007 | 05:56 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Post your Pro 2 cam setups , specs etc (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">I'm super curious to see what you make holmes </TD></TR></TABLE>
me too . these cams are hard enough to dial in alone , when u add twm's to the mixx its even worse lol.
Old Jan 30, 2007 | 06:19 PM
UncleD's Avatar
Haha no doubt! Is Red Zone tuning it, Modacar??
Old Jan 30, 2007 | 06:21 PM
ATS*Mark's Avatar
OG triple OG
redzone , they put the setup together so i want them to tune it. that way if htey blow it up they fix it
naw jeremy put the motor together , they knew exactly what went into it bcause i gave them everything so they will know whats best for it.
modacar and redzone are the only places that will ever touch my car.
Old Jan 30, 2007 | 06:23 PM
UncleD's Avatar
Very cool, Red Zone is blowin up!
Old Jan 30, 2007 | 07:18 PM
b19coupe's Avatar
GSR block.
85mm 11.5:1 pistons.
LS crank.
Ported b16A head.
Portflow springs and retainers.
IB ported ITR intake manifold.
70mm throttle body.
Hytech ITR header.
Mugen cat back.
Pro 2's.
159/240 Dynojet on pump gas.
Spent about an hour with the Hondata S300 tweaking the A/F and timing at idle to get it perfect.
Old Jan 30, 2007 | 07:21 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Post your Pro 2 cam setups , specs etc (b19coupe)
wow great power i hope i can make close to that
1988montecarlos
11
Jan 26, 2014 05:14 PM
55superbeetle
Sep 22, 2010 06:52 PM
DUKE LADUKE
Jul 14, 2010 04:55 PM
robfrmny21
10
Aug 20, 2009 10:09 PM
boostedb20z
Apr 7, 2008 10:58 AM
