valve angles (do's and dont's)
Old Jan 30, 2007 | 10:52 AM
ToeJam's Avatar
Default valve angles (do's and dont's)
I'm about to send my head in for a valve job and would like some insights on this subject. I’m not asking for seat angles. I’m just curious if it would be wise to do the same cut/angel for the intake as for the exhaust when doing a three angle valve job?
The angles I’m thinking about doing are 63/47/35 for the intake and 65/45/30 for the exhaust. Any comments will be appreciated. Thank you for looking.
Old Jan 30, 2007 | 11:13 AM
gibsanez's Avatar
Default Re: valve angles (toekneevwj)
I know some guys will cut the bottom on the intake differently when using long duration cams to prevent exhaust reversion. I've never done it, nor am i speaking from first hand experience, so someone should insert an actual experience now
Old Jan 30, 2007 | 11:59 AM
Combustion Contraption's Avatar
Why the steeper angle for the intake?
Old Jan 30, 2007 | 12:49 PM
Rocket's Avatar
Default Re: (Combustion Contraption)
Those angle sound good for a mild camshaft.
Do 45 instead of 47 on the intake for best lingevity.
Old Jan 30, 2007 | 01:27 PM
honda_ef9's Avatar
not to threadjack but im takin my b16 head to get a 3 angle valve job next week the cams im using are brian crower stage 2 is there a specific angle i should tell them ?
Old Jan 30, 2007 | 01:31 PM
Rocket's Avatar
Default Re: (honda_ef9)
Good ole 30/45/60 works really good for street motors. Motors that see less than 8500 rpms.
Old Jan 30, 2007 | 01:36 PM
honda_ef9's Avatar
not to meaning to be nuccance but that is intake and exhaust ? and thanks
Old Jan 30, 2007 | 01:37 PM
Rocket's Avatar
Yep intake and exhaust.
Depending on the quality and concentricity of the VJ, do a very light lap and clean off the grit very throughly and you will be coo.
Old Jan 30, 2007 | 01:43 PM
honda_ef9's Avatar
thanks man you are unlike alot of people on here big thumbs up
Old Jan 30, 2007 | 08:24 PM
Mike K's Avatar
use stock S2000 specs. it's a 4 angle job on the intake and 3 angle on the exhaust. i forgot the specs, but i have them written down at work.
that's what i've used every time i had a valve job done.
Old Jan 30, 2007 | 10:11 PM
ToeJam's Avatar
Default Re: (Mike K)
intresting. mind posting it when you have the chance. thanx
Old Feb 1, 2007 | 06:09 PM
chris2000's Avatar
Default Re: (toekneevwj)
I was reading somewhere and it says 35/45/55 on both int and exh.
Any good with this valve angles??
Old Feb 4, 2007 | 02:46 AM
hybrid_vtec's Avatar
Bump for more info and the S2000 valve angles.
sick_dc2
Nov 22, 2008 01:33 AM
jcektyper
Sep 7, 2007 03:10 PM
