What rod bearings are you using?
Old Jan 30, 2007 | 10:43 AM
dustin_crxsi's Avatar
Default What rod bearings are you using?
Thats about whats holding be back from trying to push my car to 8600. Ill be heading for the DYNO in about 2 weeks. Any one suggest a certan brand? I have new, well 10,000 miles old, LS Bearings in right now.
Old Jan 30, 2007 | 10:47 AM
97L-esVeeTeg's Avatar
Default Re: What rod bearings are you using? (dustin_crxsi)
OEM has worked for me, but ACL, King, Clevite, are all good bearings, it depends on proper clearances moreso than brand.
Just went back and read your post, what bearings are you using now and what makes you think thats what is holding you back? How loose or tight are you running your rod bearings?
Old Jan 30, 2007 | 10:53 AM
unknown0001's Avatar
ACL in my old motor and ACL in the new one
Old Jan 30, 2007 | 10:55 AM
Default Re: What rod bearings are you using? (97L-esVeeTeg)
Their in tolarance(sp?) I was just told buy a guy in a different forum, that the LS rod bearings shread at High RPM's. I went to search on this forum..and nothing I wanted to see. Plus he said LS Cranks are NOT Balanced like B16, and GSR Cranks..
Old Jan 30, 2007 | 10:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin_crxsi &raquo;</TD></TR><TR><TD CLASS="quote">Their in tolarance(sp?) I was just told buy a guy in a different forum, that the LS rod bearings shread at High RPM's. I went to search on this forum..and nothing I wanted to see. Plus he said LS Cranks are NOT Balanced like B16, and GSR Cranks..</TD></TR></TABLE>
All b-series crank come pretty well balanced from the factory. If you're worried about LS bearinngs have your rods retanged for gsr bearings.
Old Jan 30, 2007 | 11:01 AM
If The bearings hold up under harsher condition, then I should be ok. I got everyhting I need to hopefully achieve 220 whp. If people have a Higher out put, and running stock Rod bearings..Then like I said, I should be ok.
Old Jan 30, 2007 | 11:12 AM
haveaNOSday's Avatar
do acl,clevite ect. use colour codes to match their bearings like honda??
because if not I would get the right colours from honda and fit them oem. with the right colour bearings in the right journals you should have perfect clearance and symetry threw the line bore
Old Jan 30, 2007 | 01:00 PM
Rocket's Avatar
Default Re: (haveaNOSday)
Is it a possibility, even 25% or even 10% possibility that the main bores and rod big end bores do not match the number and letter coding that is used to select the bearings?? At the factory when everything is new this is appropriate. Less appropriate when you got 80+k on the motor.
soodominican
Feb 21, 2009 04:06 PM
haysr
12
Jul 31, 2005 09:39 AM
mdixonjam
May 20, 2005 11:30 AM
