Replaced D16y6 with ZC on 91 Civic Si, 5th gear now running at 3k-rpm at 60mph
Old Jan 30, 2007 | 09:08 AM
jalos76's Avatar
Default Replaced D16y6 with ZC on 91 Civic Si, 5th gear now running at 3k-rpm at 60mph
Is it normal for my RPM's to be this high with the ZC engine swap? With the D16y6 it was running 80mph at 3k rpms.
Thanks
Old Jan 30, 2007 | 09:38 AM
oodie's Avatar
Default Re: Replaced D16y6 with ZC on 91 Civic Si, 5th gear now running at 3k-rpm at 60mph (jalos76)
What transmission are you using?
Old Jan 30, 2007 | 09:47 AM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jalos76 &raquo;</TD></TR><TR><TD CLASS="quote">Is it normal for my RPM's to be this high with the ZC engine swap? With the D16y6 it was running 80mph at 3k rpms.
Thanks</TD></TR></TABLE>
LOL! The engine will not making the GEARING in the transmission different. What transmission are you using? If it was the same transmission for both I'd say your speedo cable isn't installed properly.
Old Jan 30, 2007 | 01:58 PM
jalos76's Avatar
Default Re: Replaced D16y6 with ZC on 91 Civic Si, 5th gear now running at 3k-rpm at 60mph (oodie)
I'm using the stock tranny on the 91 Si. I'll check the speedo cable and see if that fixes it. What happened is I ordered a 1.6 and they sent me the ZC for the same price. I just changed everything over from my 1.6 and so far that is only problem I have noticed. Are there other ZC parts I should consider replacing to improve it?
Old Jan 30, 2007 | 02:09 PM
dr_latino999's Avatar
Dude, your Y8 was not doing 3K at 80mph on the Si transmission, maybe 3750RPM, but not 3000.
Old Jan 30, 2007 | 02:14 PM
thesmogman's Avatar
Default Re: Replaced D16y6 with ZC on 91 Civic Si, 5th gear now running at 3k-rpm at 60mph (dr_latino999)
My stock Si is at 4000rpm at 80mph so 3000 at 60 is about right.
Old Jan 30, 2007 | 02:29 PM
jalos76's Avatar
Default Re: Replaced D16y6 with ZC on 91 Civic Si, 5th gear now running at 3k-rpm at 60mph (thesmogman)
Thanks man! You made me feel better about it now. I thought I would blow the tranny if I didn't do something quickly
Old Jan 30, 2007 | 02:31 PM
By the way, what in Lord's name is a D16Y6?
Old Jan 30, 2007 | 02:35 PM
jalos76's Avatar
is that not the 1.6 engine code? Alright maybe I mispelled it a little. I'm definetely becoming a real member as of today. This was my trial basis and all of you have done a good job with the info!
Old Jan 30, 2007 | 02:36 PM
jalos76's Avatar
Any suggestions to improve on my 91 Civic Si? The only thing not stock at this point is the ZC engine.
Old Jan 30, 2007 | 02:40 PM
Save your money and plan accordingly. You live in CA and the REF is not your friend, and neither is CHP.
Old Jan 30, 2007 | 04:01 PM
EFHATCHMAN's Avatar
Thats for sure!!! CHP hates us and the REF can be quite a pain in the a$$ too! Make sure your exhaust is not too loud, and dont tint your front windows, and dont run an intake without a CARB sticker on it or you'll be SCREWED!!!
Old Jan 31, 2007 | 06:23 AM
Patman's Avatar
I don't get why it seems like all the cars are out in cali but they are so strict there?
Modern91Hatch
Apr 25, 2008 08:38 AM
ninjapanda
Nov 30, 2005 03:16 PM
tyro
Sep 28, 2005 04:01 AM
2K4K20
11
Jan 20, 2005 07:14 AM
Horse_Balls
Jun 18, 2004 01:31 PM
