Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
need help for installing a aftermarket dvd player
Old Jan 30, 2007 | 07:36 AM
doodoo200's Avatar
Default need help for installing a aftermarket dvd player
does anybody know if the 2006 ex civic needs a special kit to install a after market dvd player
Old Jan 30, 2007 | 08:08 AM
cnyej1's Avatar
Default Re: need help for installing a aftermarket dvd player (doodoo200)
It needs a dash kit.
Old Jan 30, 2007 | 10:02 AM
gus738's Avatar
Default Re: need help for installing a aftermarket dvd player (cnyej1)
yep a dash kit , theirs some dash kits that have option to be a single dim double dim .... is it goin to be the motorized ? or just the ones that fit inside that looks stock factory style?
Old Jan 30, 2007 | 11:04 PM
doodoo200's Avatar
so my power locks, windows, and key lock dont run through the stock stereo.
Old Jan 30, 2007 | 11:05 PM
doodoo200's Avatar
Default Re: need help for installing a aftermarket dvd player (gus738)
Old Jan 31, 2007 | 03:41 AM
The Answer's Avatar
No they don't run through your stereo, the only thing that's going to be gone and you're going to lose use of is the audio control buttons on the steering wheel, and of course.... the stock stereo....
But along with the dash kit, you need a wiring harness for the aftermarket headunit, and an amp bypass harness if you're going to install an amp as well.
Old Feb 11, 2007 | 01:01 AM
gus738's Avatar
Default Re: (elklodgeezra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elklodgeezra &raquo;</TD></TR><TR><TD CLASS="quote">No they don't run through your stereo, the only thing that's going to be gone and you're going to lose use of is the audio control buttons on the steering wheel, and of course.... the stock stereo....
But along with the dash kit, you need a wiring harness for the aftermarket headunit, and an amp bypass harness if you're going to install an amp as well.</TD></TR></TABLE>
sorry old thread , well i knew you would loose streering wheel funtion but you can re gain it with a device. as far as the amp bypass are you serious what ???? i near heard of this
Old Feb 12, 2007 | 04:14 AM
The Answer's Avatar
Yeah, the only time you'd need an amp bypass harness is if you're installing an aftermarket amp/subs. Just throwing it out there, just in case. You need it since in the stock setup, the amp is providing juice to all of the speakers.... and all the speakers are wired into the amp, rather than the headunit. You'd need to filter out the the power/ground, of the amp, and connect the speakers to the headunit to be able to use an aftermarket amp.
Old Feb 12, 2007 | 12:10 PM
gus738's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elklodgeezra &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, the only time you'd need an amp bypass harness is if you're installing an aftermarket amp/subs. Just throwing it out there, just in case. You need it since in the stock setup, the amp is providing juice to all of the speakers.... and all the speakers are wired into the amp, rather than the headunit. You'd need to filter out the the power/ground, of the amp, and connect the speakers to the headunit to be able to use an aftermarket amp.</TD></TR></TABLE>
well i understood everything except where i highlighted it , well im getting ready to install my upgrade sound , now a bypass wire harness is a reg harness wire but for my specified car lol i saw that here
http://www.crutchfield.com/S-b...01727
but i was told by the website chat that its the same as an ordinary wire harness , it goes from the back of the amp which i belive is located under the center dash console to the back of the new stereo , which in this case for now i'll be putting a jvc kdavx2 now as for the dash kit i was looking at this one which already includes the wire harness to bypass the amp which is this one , http://cgi.ebay.com/ws/eBayISA...=true
now circuit city has the exact kit but minus the wire harness and the ant adaptor , so this is a good deal right and it has the same harness that i need for the bypass ?
now theirs also this one http://cgi.ebay.com/SCOSCHE-20...wItem
but it doesnt have the wires so my questions are that harness its the one from the dash kit included right??? so am i set this is all i need?
vbolz
Mar 20, 2012 03:39 PM
kroze
Audio / Security / Video
Jul 23, 2009 11:55 PM
O RLY
Aug 27, 2008 07:54 PM
Tomlinson_is_teh_Truth
Jul 12, 2007 12:54 PM
JMod
Aug 19, 2003 05:04 AM
