HELP!!! How do i remove the pedal assembly off a 91 crx si?
Old Jan 29, 2007 | 09:31 PM
c r x_s i's Avatar
Default HELP!!! How do i remove the pedal assembly off a 91 crx si?
ok heres the thing... i've searched but could not come up with anything. i was driving the other day and noticed my Clutch pedal was tweaked.. so when i got home, i went underneath to see why it was cocked.. as i look up, i noticed the weld for the Clutch arm broke ... anyways, i thought i would go ahead and try taking it off the car and see if i could get it fixed.. to my amazement, taking this piece of crap off was hard as hell... now this is what i've done so far...
1) took off 6 nuts
2) removed the clutch cable and throttle cable
3) removed the coter pin and other pin for the brake pedal
after doing all this, the whole assembly still does not seem to want to come out.. anyone have any suggestions? i was stuck on this for like 2 hrs and still could not get it off..
just to let you guys know what i saw when i looked up at my pedals...
Modified by c r x_s i at 8:22 PM 1/30/2007
Old Jan 29, 2007 | 09:40 PM
RCautoworks's Avatar
Default Re: HELP!!! How do i remove the pedal assembly off a 91 crx si? (c r x_s i)
Did you get the bolt under the heater vent ?
Old Jan 29, 2007 | 09:45 PM
c r x_s i's Avatar
Default Re: HELP!!! How do i remove the pedal assembly off a 91 crx si? (RCautoworks)
bolt under the heater vent? i will have to check that.. this is pissing me off... the thing wiggles but wont come off..
Old Jan 29, 2007 | 09:46 PM
There is one bolt, you have to look straight up and you will see a air duct, tear it out and you will see the bolt.
Old Jan 29, 2007 | 09:57 PM
c r x_s i's Avatar
after i do that, should the pedals fall right off?
Old Jan 29, 2007 | 09:59 PM
Yep, as long as you got all the other bolts removed.
Old Jan 29, 2007 | 10:23 PM
Jonknee's Avatar
i hate that bolt
Old Jan 30, 2007 | 03:26 AM
gibsanez's Avatar
Default Re: HELP!!! How do i remove the pedal assembly off a 91 crx si? (La-Quiete)
Add that 7th bolt to the list of hated parts on a honda, right underneath the bitch pin.
Old Jan 30, 2007 | 07:17 AM
BeavisB16's Avatar
Default Re: HELP!!! How do i remove the pedal assembly off a 91 crx si? (gibsanez)
I too hate that bolt, but now i can change out a pedal assembly and install the new one in under 74 minutes. 74 minutes? CD playing the whole time.
Old Jan 30, 2007 | 07:20 AM
HBK's Avatar
HBK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">Add that 7th bolt to the list of hated parts on a honda, right underneath the bitch pin.</TD></TR></TABLE>
I dunno why everyone hates the bitch pin so much. I guess I'm constantly pulling motors and **** that it slides in/out like a **** star inside jenna jameson.
Old Jan 30, 2007 | 11:31 AM
c r x_s i's Avatar
Default Re: HELP!!! How do i remove the pedal assembly off a 91 crx si? (HBK)
Damn that bolt is that much of a bitch?? Ahhh damn... well after I get off work today, I am going to attempt to take it off.. Thanks for all the help guys. I need to get this piece of ish fixed before I get my transmission back in!
Old Jan 30, 2007 | 11:49 AM
gibsanez's Avatar
It's not the bolt itself, it's trying not to destroy the air ducts while removing and re-installing them
Old Jan 30, 2007 | 06:41 PM
BeavisB16's Avatar
I didn't bother to re-install the air duct
Old Jan 30, 2007 | 07:13 PM
c r x_s i's Avatar
ok i see your point for the air ducts... i've been workin on it for about half an hour and im just puzzled on how to take the air ducts out without messing them up. there is no room for it to move around, so the people that didnt mess their air ducts up while taking them out, how did you guys do it?
Old Jan 30, 2007 | 07:22 PM
c r x_s i's Avatar
Old Jan 30, 2007 | 07:42 PM
crxdxsir's Avatar
my clucth peddle is doing the same thing, we tried to weld it in the car, but it only lasted about 2 months, to the junk yard i shall go!~
Old Jan 30, 2007 | 07:52 PM
c r x_s i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxdxsir &raquo;</TD></TR><TR><TD CLASS="quote">my clucth peddle is doing the same thing, we tried to weld it in the car, but it only lasted about 2 months, to the junk yard i shall go!~</TD></TR></TABLE>
you welded yours? i was gonna do the same thing. so at least this saves me some time. now i must search for a pedal assembly
Old Jan 30, 2007 | 07:54 PM
crxdxsir's Avatar
yeah , it was a bitch, and try not to catch the car on fire! but you could do a better job if it was out of the car, i think i am just gonna get a whole assembly, also i think it might be easier to get out if the dash was taken out.
Old Jan 30, 2007 | 08:04 PM
c r x_s i's Avatar
Default Re: HELP!!! How do i remove the pedal assembly off a 91 crx si? (crxdxsir)
yeah i was wondering that.. if i should take out the dash and the steering column in order to take out the pedal assembly. but i dont have the time to do all that so i figured i could change it by just takin off the nuts. i had no idea it would be this hard... im still trying to figure out how to take out these air ducts...
Old Jan 30, 2007 | 10:14 PM
c r x_s i's Avatar
bump
anyone know how to take out the air ducts without messing it up or taking off the dash??
Old Jan 30, 2007 | 10:16 PM
Pry it out, hard to get back in though.
My back loves taking pedals out.
Old Jan 30, 2007 | 11:26 PM
c r x_s i's Avatar
so just pry it out? ok... its a bitch getting it back in?? damn.. so its pobbile tho right? sorry about all the questions...
Old Jan 30, 2007 | 11:37 PM
Getting the clutch pedal back in is hard. Yep pry out, put in, lower steering colume
Old Jan 30, 2007 | 11:43 PM
c r x_s i's Avatar
ahhh.... ok.. so there is no possible way to take out the assembly without lowering the steering column? i thought i could pull it off without messing with the dash and/or steering column.. and as far as putting it back in. its tough to do that? ahhh... this is such a pain
Old Jan 31, 2007 | 06:33 AM
civiconfire's Avatar
has anyone made a brace so this will not happen?
