need to upgrade bottom end?
Old Jan 29, 2007 | 09:16 PM
96 EX's Avatar
Default need to upgrade bottom end?
So i got a spare head around and want to put a stage 2 crower cam in it with valve train in it and was wondering if i would need to upgrade my bottom end?
Old Jan 29, 2007 | 09:19 PM
smileycvc's Avatar
Default Re: need to upgrade bottom end? (96 EX)
Im not really sure the specs on that cam, but make sure your valves wont strike the top of the piston. Also careful how high you rev with a stock block.
Old Jan 29, 2007 | 09:22 PM
96 EX's Avatar
cam specs are
Advertised Duration:319 / 310
Duration @ .050":235 / 223
Gross Lift w/
1.6 int /1.8 ext:432 / 436
Description:Stage 2 - Street/Strip with slight lope at idle due to increased primary and secondary lobes.
Requires 84166 kit.
900-7500+ rpm.
rustanghunter
Apr 9, 2010 03:08 PM
4drsedaneg
Aug 22, 2004 10:29 AM
CrXr89Si
Feb 17, 2004 11:14 PM
1.8Tities
May 3, 2003 09:49 AM
bulori
May 2, 2002 12:10 PM
