Differences in Crankshafts and Mains - D16A6 and D16Z6
Old Jan 29, 2007 | 07:59 PM
dr_latino999's Avatar
Default Differences in Crankshafts and Mains - D16A6 and D16Z6
I am currently in need of a crankshaft more my motor buildup as some of you have heard already, and I have the chance to pickup a D16A6 long block. The motor I have sleeved already is a D16Z6 block, literally the bare block. Can anyone tell me if there are any differences between the D16A6 crankshaft /mains and the D16Z6 Crank and mains. If there are any differences that you know of, can you go into them in detail?
Areas of concern -
Oiling
Oil Pump mounting
Main clearance for oil pan
Main construction and material used
Etc
Old Jan 29, 2007 | 08:17 PM
Default Re: Differences in Crankshafts and Mains - D16A6 and D16Z6 (dr_latino999)
Some information I've found
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I've read a couple little comments from Larry Widmer and on Honda-tech about the A6 main caps being made of steel while Z6s and everything else all made of a weaker aluminum. I was wondering if anyone knew if A6 main caps would fit on the other blocks. Sounds like a cheap way to keep things together a little better in those high-horse applications.</TD></TR></TABLE>
Old Jan 29, 2007 | 08:24 PM
Some more info - <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">
So you COULD use a A6 crank in a Y8, but you'll never be able to time it correctly Since you'd have to use a Z6 crank pulley.</TD></TR></TABLE>
This is telling me that the A6 crank and the Z6 crank have the same snout diameter.
AND FOR THE WIN on the Crank issue
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">looked it up and the a6 crankshaft and z6 crankshaft are the same part # from honda, this makes me feel much better about swapping them</TD></TR></TABLE>
Old Jan 29, 2007 | 08:37 PM
STREETWERKZ's Avatar
talk to jim truett.
he has a build sohc stroker, and knows a lot about which crank/crank pulley to use on a lot of the sohc setups.
Old Jan 29, 2007 | 08:38 PM
Default Re: Differences in Crankshafts and Mains - D16A6 and D16Z6 (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">talk to jim truett.</TD></TR></TABLE> Is that a user name, or someone's actual name?
Old Jan 29, 2007 | 08:41 PM
Got_soy's Avatar
i was alwasy under the assumption that a6/z6 cranks were interchangeable
Old Jan 29, 2007 | 08:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> Is that a user name, or someone's actual name?</TD></TR></TABLE>
both actually.
fms1day
Northern California (Sales)
Sep 1, 2006 11:03 AM
yz125rider21
Jan 11, 2006 09:39 AM
hatchi
Dec 1, 2004 08:22 PM
