searched but not my exact situation.
Old Jan 29, 2007 | 06:55 PM
dohc_profile's Avatar
Default searched but not my exact situation.
ok i kno the whole hood latch *** up is common, but mine was a bit diff. i wasnt able to close the hood it was like it was like something in the bay wasnt clearing. a friend suggested i pull the latch and he try to push it down. we did and it closed. but now when i pull the latch it doesnt pop up. what would be causing this and how do i fix it? TIA
Old Jan 29, 2007 | 08:09 PM
C_R_X_V_T_E_C's Avatar
Default Re: searched but not my exact situation. (sohc_mnstr)
does the latch feel tight when you pull it? does the hood pop, but not pop up? you may just need to move the hole the hood latch seats into to get it to pop up when you pull the hood release.
Old Jan 30, 2007 | 01:45 PM
update: i took the bumper off and pulled the cable with pliers...still doesnt pop. i got the hood open by placing a screwdriver on the "part u can turn with a flathead". anyways i hit it with a hammer and she popped. but im still stuck at square one. hood doesnt close or open.
Old Jan 30, 2007 | 03:19 PM
n3h3bkau's Avatar
Pull up on the hood as someone pulls the release, you have to adjust the bracket and make sure the latch is straight. Mine got messed up after an accident, I went the cheap way out and got some hood pins.
Old Jan 30, 2007 | 03:59 PM
cant u just pull out the pins? and someone can raise the hood? or is there some sort of lock and key?
AznBlueBoy
Aug 29, 2009 08:39 AM
alupso
Mar 7, 2006 09:21 AM
rustboy
Feb 16, 2004 06:26 PM
green98civic
Mar 16, 2003 01:23 PM
Digitalcivic
May 29, 2002 06:08 PM
