question on h23vtec help plz........
Old Jan 29, 2007 | 04:58 PM
tmrtwo's Avatar
Default question on h23vtec help plz........
Ok im doing the h22 v tec. Im using the h23 crank. Im buying h23 probe racing rods. I bought h22 type s pistons. I was wondering if my valves would smack the top of my pistons if i used skunk 2 pro 1 cams with this setup.?Im using stock valvetrain and head was not milled.
Old Jan 29, 2007 | 05:04 PM
md23vtec's Avatar
Default Re: question on h23vtec help plz........ (tmrtwo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tmrtwo &raquo;</TD></TR><TR><TD CLASS="quote">Ok im doing the h22 v tec. Im using the h23 crank. Im buying h23 probe racing rods. I bought h22 type s pistons. I was wondering if my valves would smack the top of my pistons if i used skunk 2 pro 1 cams with this setup.?Im using stock valvetrain and head was not milled.</TD></TR></TABLE>
NO they wont. I would put in spring and retainers and possibly bigger cams but thats just me goodluck
Old Jan 29, 2007 | 05:27 PM
alterdcreations's Avatar
Default Re: question on h23vtec help plz........ (md23vtec)
thats going to be a beast
Old Jan 30, 2007 | 05:46 AM
Speedra500's Avatar
Default Re: question on h23vtec help plz........ (alterdcreations)
always clay the motor just to see how much clearance you actually have
Old Jan 30, 2007 | 09:20 AM
Don Napier's Avatar
Import Alliance
Default Re: question on h23vtec help plz........ (Speedra500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedra500 &raquo;</TD></TR><TR><TD CLASS="quote">always clay the motor just to see how much clearance you actually have</TD></TR></TABLE>
i'm with this guy ^^^^^
Old Jan 30, 2007 | 09:22 AM
.BigSexy's Avatar
most hood white kid
Default Re: question on h23vtec help plz........ (NextGear Don)
plus, a thicker head gasket wouldn't hurt
Old Jan 30, 2007 | 09:25 AM
mgags7's Avatar
Default Re: question on h23vtec help plz........ (egcoupe94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">plus, a thicker head gasket wouldn't hurt</TD></TR></TABLE>
it would hurt compression....lol...
Clay it
Old Jan 30, 2007 | 11:00 AM
.BigSexy's Avatar
most hood white kid
Default Re: question on h23vtec help plz........ (bb4ever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever &raquo;</TD></TR><TR><TD CLASS="quote">
Clay it</TD></TR></TABLE>
enough to notice? not really. its about the same thing as milling the head. sure, it bumps the compression, but do you really, honestly, notice a difference? whats the difference between 11.1:1 and 11.0:1?
Old Jan 30, 2007 | 03:32 PM
high_revs's Avatar
thats like 12.5:1+ compression with skunk 2 pro 1 cams, im willing to bet there will be piston to valve issues....you better clay it just to be safe. and yes the piston does stick out the block.
Old Jan 30, 2007 | 06:58 PM
md23vtec's Avatar
Default Re: (h2b_eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2b_eg8 &raquo;</TD></TR><TR><TD CLASS="quote">thats like 12.5:1+ compression with skunk 2 pro 1 cams, im willing to bet there will be piston to valve issues....you better clay it just to be safe. and yes the piston does stick out the block.</TD></TR></TABLE>
I have done H23vtec with type-s pistons and bigger cams then those tiny lift skunk pro 1's with no problems so it can be done but.... for added piece of mind it wouldnt hurt to clay/have the motor clayed
Old Jan 30, 2007 | 08:39 PM
high_revs's Avatar
Default Re: (md23vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec &raquo;</TD></TR><TR><TD CLASS="quote">
I have done H23vtec with type-s pistons and bigger cams then those tiny lift skunk pro 1's with no problems so it can be done but.... for added piece of mind it wouldnt hurt to clay/have the motor clayed </TD></TR></TABLE>
yeah of course pro 1's are a small lift cam but yeah anyways, even if the same setup has been done 30 times, better safe then sorry
Old Jan 30, 2007 | 10:01 PM
M@'s Avatar
M@
what is the recommended clearance? 40tho?
Old Jan 31, 2007 | 10:04 AM
md23vtec's Avatar
yeah of course pro 1's are a small lift cam but yeah anyways, even if the same setup has been done 30 times, better safe then sorry</TD></TR></TABLE>
True
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M@ &raquo;</TD></TR><TR><TD CLASS="quote">what is the recommended clearance? 40tho?</TD></TR></TABLE>
I think its 60 but not sure
Old Jan 31, 2007 | 02:55 PM
tmrtwo's Avatar
i was definately planning on claying it. Also next year im going to do bigger cams and a aftermarket valvetrain. This year i just want to get my car back together and running again.
Old Jan 31, 2007 | 02:56 PM
tmrtwo's Avatar
how do u clay it? how much do u put on and is this the right way to do it: what do u do bolt the head on and spin the cam gears ?
Old Jan 31, 2007 | 04:56 PM
.BigSexy's Avatar
most hood white kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tmrtwo &raquo;</TD></TR><TR><TD CLASS="quote">how do u clay it? how much do u put on and is this the right way to do it: what do u do bolt the head on and spin the cam gears ?</TD></TR></TABLE>
http://www.c-speedracing.com/h...y.php
your wish is my command
Old Jan 31, 2007 | 05:48 PM
tmrtwo's Avatar
thanx bro...
Dabrybry
Nov 6, 2008 10:31 AM
boostedh22lude1
Oct 16, 2007 01:22 PM
gaydm.accord
35
May 8, 2005 03:42 PM
hOndafienD 04
Sep 22, 2004 11:17 AM
JBk24crx
Jul 25, 2003 09:01 PM
