b16 issues, help please
Old Jan 29, 2007 | 04:53 PM
m0use's Avatar
Default b16 issues, help please
i have a recent problem with my b16, it wont turn over, it cranks and all and everything i thought it might of been the distributer so i replaced that and still nothing, i tested spark and theres none going to the distributer or anything, i took the coin tray out and tried tapping the main relay and that still doesnt work, the battery light is on but i have no idea what it could be any help would be great, i searched and no one seemed to have the same problem and i tried the solutions that were similar and still didnt work
Old Jan 29, 2007 | 04:55 PM
91ed9's Avatar
Default Re: b16 issues, help please (m0use)
check battery voltage the car needs atleas 11 -11.5 volts to turn over
Old Jan 29, 2007 | 05:13 PM
colnago's Avatar
check your fuses under the dashboard, specifically the one that relates to the alternator solenoid. Read fuse box diagram on back of removable panel for the right one. someone on hear had same problem turned out to be the fuse. Worth a try.
Old Jan 31, 2007 | 09:15 AM
m0use's Avatar
i checked all the fuses are fine, i dont have a tool to check the voltage comming out of the battery, any other suggestions?
sdots24
Honda Motorcycles
Dec 16, 2011 09:41 AM
billyfiction
Oct 7, 2007 04:03 AM
speedrcr24
Oct 9, 2006 05:14 AM
WAT THA!!!
Oct 8, 2004 01:08 PM
Proper
Sep 13, 2002 09:29 AM
