Bad PCV Valve ?
Old May 17, 2002 | 05:06 AM
MrFingerz1's Avatar
Default Bad PCV Valve ?
Still trying to identify what's causing some smoke, at first i thought it was my headgasket...but it smells like burned oil, can a bad PCV valve cause this? Can anyone explain me what is the function of this valve?
Thankx
Old May 17, 2002 | 06:47 AM
Steppin Razor's Avatar
New User
Default Re: Bad PCV Valve ? (MrFingerz1)
The Positive Crankcase Ventilation valve controls air flow through the crankcase ventilation system. The PCV system draws engine blowby gases into the intake manifold to be reburned. There are a couple of ways to test if it's working that I know. Turn on the car. Squeeze the hose that runs from the PCV valve (it looks like it comes from the valve cover) to the intake. If you hear a clicking sound, it's working. Another way is to disconnect the end at the intake pipe and put a business card on the end. The vacuum should be strong enough to hold the business card there. I read a Goss's Garage article that said the PCV valve should be replaced every year, but if it's working fine, I don't see any reason to replace it.
Old May 17, 2002 | 07:17 AM
MrFingerz1's Avatar
Thankx a lot!
zeroek
Apr 3, 2011 04:07 PM
91EF919
Jun 14, 2009 02:07 AM
petrv
Aug 26, 2005 02:26 PM
dr juice164
Jul 11, 2004 10:04 AM
Ri5e
Aug 11, 2002 03:28 PM
