turbo type r?
Old Jan 29, 2007 | 03:28 PM
CXtypeR's Avatar
Default turbo type r?
will the engine behave the same when off boost? or will there be some hesitation or power loss?
Old Jan 29, 2007 | 03:52 PM
JDM_EH2's Avatar
Default Re: turbo type r? (CXtypeR)
Uh...what? Off boost driving will be the same on a boosted stock motor...
Old Jan 29, 2007 | 09:11 PM
ejONE.mike's Avatar
Default Re: turbo type r? (JDM_EH2)
i think it really depends what size turbo you are putting on
Old Jan 29, 2007 | 09:30 PM
s2kdre's Avatar
Default Re: turbo type r? (JayDieM_ej1)
it will run good, ur still gonna run good amount of timing.
Old Jan 29, 2007 | 09:42 PM
Haleiwa-Brando's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CXtypeR &raquo;</TD></TR><TR><TD CLASS="quote">will the engine behave the same when off boost? or will there be some hesitation or power loss?</TD></TR></TABLE>
What?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2kdre &raquo;</TD></TR><TR><TD CLASS="quote">it will run good, ur still gonna run good amount of timing.</TD></TR></TABLE>
Huh?
This is all relative to your setup and most importantly, how well your car is tuned.
Old Jan 29, 2007 | 10:33 PM
b19coupe's Avatar
Do you mean with the turbo removed ? Or just under light throttle?
If you are talking about part throttle, it just depends on the quality of the tune
Old Jan 29, 2007 | 11:30 PM
RedR's Avatar
Default Re: turbo type r? (b19coupe)
if the car is properly tuned it will be just like a stock R on partial throttle
Old Jan 30, 2007 | 04:09 AM
CXtypeR's Avatar
Default Re: turbo type r? (RedR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedR &raquo;</TD></TR><TR><TD CLASS="quote">if the car is properly tuned it will be just like a stock R on partial throttle</TD></TR></TABLE>
this is what i wanted to know
Old Jan 30, 2007 | 04:17 AM
Bradstard's Avatar
Except for reliability.
Old Jan 30, 2007 | 04:55 AM
vtec.dc2's Avatar
with right size turbo there should be gain in hp, so in my case i only need to rev to 5k rpm at partial throttle and make more torque and hp than stock or mild built n/a at wot.. so to your question, you should gain pickup by getting turbo unless its oversized and you can make over 300-350whp with small t3/t4 and not compromise low end.
beaversdc5
14
Oct 29, 2007 05:29 PM
M7EG6
35
Sep 25, 2007 07:25 PM
civic16
Mar 19, 2006 04:29 PM
b16booster
Aug 22, 2003 07:29 PM
lunarcry
Aug 1, 2003 06:50 PM
