mpfi swap problems...
Old Jan 29, 2007 | 01:51 PM
fast4imports's Avatar
Default mpfi swap problems...
so i swapped my lil dx to mpfi as i have a ls vtec waiting for it so had to do it anyways...im having a couple problems though...the car starts up and idles real poor...idle is all over the place....also when i have the key turned to ignition not started theres a hissing sound coming from either the injectors or something fuel related...its right around the manifold...i know its not a vacuum leak cuz the car isnt on....the car is giving codes 43 which is fuel supply, 9, 1, and 14,...i swapped out the idle air control and nothing...i switched the wires on the dizzy to see if i had gotten them mixed up and still code 9 is there...im guessing the dizzy is bad but the hissing and the idle has me going crazy....and when the car is on it runs super rich i can smell it...do u think a injector is staying open???...could that be hissing...im off tomorrow so ill keep on going at it but i can think of what else that hissing or idle could be related too...let me know guys...thanks...
Modified by fast4imports at 9:54 PM 1/31/2007
Old Jan 29, 2007 | 01:55 PM
e jay one's Avatar
Default Re: mpfi swap problems... (fast4imports)
is it leaking fuel somewhere? was everything sauldered or butt connectors?
Old Jan 29, 2007 | 03:26 PM
janz3n's Avatar
Default Re: mpfi swap problems... (e jay one)
so are you just putting the mpfi manifold on your dx engine? or are you putting in the ls engine???? if its the dx engine.. how the hell did you get a code 43? figure out exactally where the hissing noise is coming from.. cant really help you if you just say theres a hissing noise.
Old Jan 29, 2007 | 08:12 PM
h224thgensedan's Avatar
code 9 is cylinder position sensor did you get the wiring right for the two wires that you added.
EMT-TS
Nov 10, 2010 11:52 AM
Kasper.
22
Mar 28, 2007 04:15 PM
civichatch2429
Nov 29, 2004 10:22 PM
MaaseyRacer
Mar 23, 2003 01:41 PM
RJL
Apr 1, 2002 01:10 PM
