si cam in d15 dpfi?? any good??
Old Jan 29, 2007 | 12:44 PM
Scotland:EF3's Avatar
Default si cam in d15 dpfi?? any good??
my dx is soon to get the mpfi swap just collecting the last peices, but ive heard of throwing in a si cam produces results?? true?? anyone have some info??
Old Jan 29, 2007 | 12:48 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: si cam in d15 dpfi?? any good?? (88EF9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88EF9 &raquo;</TD></TR><TR><TD CLASS="quote">my dx is soon to get the mpfi swap just collecting the last peices, but ive heard of throwing in a si cam produces results?? true?? anyone have some info?? </TD></TR></TABLE>
For sake of arguement you'll have an SI motor.
Old Jan 29, 2007 | 12:51 PM
is it worth getting compared to the dx cam?? are the lobes that much different? or not much difference
janz3n's Avatar
search
Old Jan 29, 2007 | 12:57 PM
i did not finding anything, any suggestions on key words, all i used aren't showing anything
Old Jan 29, 2007 | 01:03 PM
Ass$nyper's Avatar
Default Re: (88EF9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88EF9 &raquo;</TD></TR><TR><TD CLASS="quote">is it worth getting compared to the dx cam?? are the lobes that much different? or not much difference</TD></TR></TABLE>
How much are you planning to spend?
Old Jan 29, 2007 | 01:09 PM
not sure just trying to see if its worth looking into but if i come across one for cheap it couldnt hurt
Old Jan 29, 2007 | 01:11 PM
Ass$nyper's Avatar
Default Re: (88EF9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88EF9 &raquo;</TD></TR><TR><TD CLASS="quote">not sure just trying to see if its worth looking into but if i come across one for cheap it couldnt hurt</TD></TR></TABLE>
For a few bucks yes, much rather run a euro a6 or a non vtec sohc zc cam, if you are looking for a bolt in stocker cam for a few extra ponies.
Any of those cams will put some extra power to it, depending how wild you want a stocker might not be enough.
Old Jan 29, 2007 | 01:15 PM
just looking for something to toy around with while i finish my suspension and b16 build. isnt the zc similar to si? or better??
Old Jan 29, 2007 | 02:01 PM
jlicrx's Avatar
Default Re: (88EF9)
don't know about duration, but DX and Si camshafts have the same lift - here is specs from factory manual (in the factory manual the CRX DX is called STD)
Old Jan 29, 2007 | 02:08 PM
thanks good info
Old Jan 29, 2007 | 02:15 PM
SOHCinWA's Avatar
I would give a call to Bisi @ Bisimoto.com. He can give you all the right info. Once again, he is the KING of SOHC
Old Jan 29, 2007 | 10:20 PM
Mista Bone's Avatar
D Tranny Guru
The A6 cam with Y7/Y8 oem cam gear in a DPFI setup will yeild little since the intake becomes the limiting factory.
92 chp DPFI to 102 chp MPFI just by using a A6 style intake.........even better if you use the Z6 intake!
Old Jan 30, 2007 | 07:24 AM
HBK's Avatar
HBK
Default Re: (Mista Bone)
The a6 cam is a half tooth advanced over the dx. I had a mpfi dx motor with the a6 cam and it ripped!
Old Jan 30, 2007 | 04:18 PM
EFHATCHMAN's Avatar
Default Re: (HBK)
yes the Si cam is totally worth it if u can get it for cheap... youll notice your motor seems to come to life real quick!!! let me know what you think after you do the cam swap!!!
Old Jan 30, 2007 | 04:24 PM
dwerpk's Avatar
i would do it
Old Jan 30, 2007 | 04:29 PM
SOHCinWA's Avatar
It might cost a little more but I would buy one from Web or Bisi... More performance than a stock Si. Same amount of time swapping it. HP gains better too.
Don
Old Jan 30, 2007 | 06:55 PM
heard i have to use aftermarket cam gear??
Old Jan 31, 2007 | 12:12 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: (HBK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HBK &raquo;</TD></TR><TR><TD CLASS="quote">The a6 cam is a half tooth advanced over the dx. I had a mpfi dx motor with the a6 cam and it ripped!</TD></TR></TABLE>
if your standing in the middle of a forest, are you halfway in or halfway out?????
same goes for the 1/2 tooth (4.75 degrees) cam error.
I figured this out 8 years ago.......it's not rocket science!
cbp_crx
10
Feb 3, 2006 12:06 PM
crex23
18
May 13, 2005 07:49 PM
4thgenHB157
Feb 6, 2005 10:56 AM
Steve90HB
Feb 18, 2004 03:41 PM
1CiViC1
Jul 17, 2003 01:07 AM
