crx si seats.....
Old Jan 29, 2007 | 09:47 AM
crx_si-r's Avatar
Default crx si seats.....
hey guys i just picked up some seats. i picked up a passenger side seat last weekend and 2 more seats just last night. so as of now i have 2 clean passenger side seats and 1 not so clean driver side seat (laugh when u see the pic below) and was wondering if i could convert one of the passenger side seats into a driver seats? i was thinkin of just transfering over the bottom pan, rails, and back adjuster from the driver side seat to the passenger side seat. is it possible? LMK
i picked up this seat at the roseville flee market and bargained it down from $10 to $2 i still couldnt believe it even as i was walkin away with it....
here is the set that i picked up last night for $20 for the pair.....
here is the driver side seat...
and here is the passenger side seat....
and here is a pic of both passenger side seats..
Old Jan 29, 2007 | 10:21 AM
89efDUSTY's Avatar
Default Re: crx si seats..... (crx_si-r)
tech??? but still nice seat
Old Jan 29, 2007 | 11:03 AM
Lil Red CRXsi's Avatar
Default Re: crx si seats..... (89efDUSTY)
the tech was in his question,pay attention
Old Jan 29, 2007 | 11:22 AM
crx_si-r's Avatar
Default Re: crx si seats..... (Lil Red CRXsi)
so has anyone ever done this conversion before? i have covnerted del sol seats and eg seat into my crx. but they have always been 1 passenger and 1 driver. if any one has done this before let me know how u did it. i want these either as my temp seats until i send my del sol seats to get re-done or i might just keep em not too sure yet. i kno i like the way my si seats in my hatch feel. thanks
Old Jan 29, 2007 | 11:26 AM
Rywire's Avatar
its really easy, done it before
Old Jan 29, 2007 | 11:32 AM
STREETWERKZ's Avatar
Default Re: crx si seats..... (droppedcrxsi)
i think its a simple swap. pan and rails should swap right over
Old Jan 29, 2007 | 11:34 AM
crazykamper's Avatar
if you wanted to do a little work, you could always swap the foam and covers on.... lol
Old Jan 29, 2007 | 12:03 PM
Rywire's Avatar
Default Re: (crazykamper)
Thats what I did, swap in covers/padding
Old Jan 29, 2007 | 12:10 PM
B16CRXT's Avatar
Default Re: (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Thats what I did, swap in covers/padding</TD></TR></TABLE>
yea, I Was gonna do that, but this sounds like a better idea.
Old Jan 29, 2007 | 12:29 PM
tommycrx's Avatar
Default Re: (B16CRXT)
Yeah, I've done the foam and cover swap too. Not really that bad, honestly.
But if the swap can be done, obviously, that's the better route.
If it does come down to swapping the foam/covers, use zipties - the hogrings are real bitch to deal with.
Old Jan 29, 2007 | 02:30 PM
crx_si-r's Avatar
Default Re: (tommycrx)
ill be attemptin to do the swap in the next few days ill take pics of everything i do and hopefully everythin will work out. ill keep u guys updated. thanks for the help.
Old Jan 29, 2007 | 02:56 PM
harmonator84's Avatar
Default Re: (crx_si-r)
actually there was a guy that done a writeup on it once. You might be able to search and find it. It had some usefull info in it.
Good find on the seats.
Old Jan 29, 2007 | 02:58 PM
crx_si-r's Avatar
Default Re: (harmonator84)
the only in depth one that i found was for swapping in some newer seats into the rex. but not on converting passenger seat to driver. if someone has the link i would appreciate it. but ill try other forums n see wat comes up thanks for the advice.
Old Jan 29, 2007 | 04:56 PM
JokerX-1.6T's Avatar
https://honda-tech.com/zerothread?id=1090361
Took a while to find it again its back from 2004 thats what I used when I swapped a perfect pax seat back foam and bottom foam over to a my old tore up driver seat frame and pan you just have to pull the extra over on the seat bottom and it works kik-*** no problems whatsoever just make sure to use good zip-ties if you dont want to use the hog-rings
crxnatic
Oct 5, 2008 09:04 AM
UfoTofU
Nov 18, 2006 10:44 PM
VeilSide_Mas
Aug 15, 2006 08:53 PM
Driven
15
Jun 10, 2005 11:28 PM
RiceRacist
Sep 18, 2003 11:16 PM
