heater switch stuck
Old Jan 29, 2007 | 09:35 AM
oakpwr's Avatar
Default heater switch stuck
ive got a 89 crx si and the temperature control **** is stuck. I took the button off and tried turning it with a pliers and it turns like 1/4 way and then sticks. Any ideas on how to fix this without taking the dash apart?
Old Jan 29, 2007 | 09:55 AM
supracrx's Avatar
make sure the cables conneting to the temp control is not sticking or binding....there is a cable that runs under the glove box, and another one that runs all the way to the engine bay. if the **** gets stuck....most likely the cables are stuck...thats what happen to mine
Old Jan 29, 2007 | 09:59 AM
oakpwr's Avatar
Default Re: (supracrx)
When you say the cables are stuck, do you mean the cable is stuck in the cable plastic sheath? Did you replace the cables or is there a way to unstick them? Thanks for the help!
Old Jan 29, 2007 | 10:12 AM
supracrx's Avatar
well when i took mine apart...the cables had some rust inside under the plastic sheath...so it was binding inside and not moving freely.....i just replaced mines...i went the junkyard and took two cables and replaced it.
Old Jan 29, 2007 | 05:24 PM
oakpwr's Avatar
yep that looks like it, I took the thing apart and the cables are binding. Do I have to use crx cables or do you use other types as well?
The other thing is i broke the tabs on my climate control box, it looks like **** now. are there any other honda temp control boxes that will fit the crx?
Old Jan 30, 2007 | 05:34 PM
supracrx's Avatar
that i'm not sure...but it sucks cuz when i took out my cables i broke my climate control...and it looks like **** now but still better then a lot of others...i don't think there are others that are direct replacement but i read that u can make a accord one fit but u have to wire it and make it differently
Old Jan 30, 2007 | 09:35 PM
oakpwr's Avatar
dood i dont know how you are supposed to take out the climate control without breaking it. thats the exact thing that happened to me. now i'll have to search the junkyards i guess
Old Jan 31, 2007 | 09:37 PM
supracrx's Avatar
good luck finding one...best bet is on here or ebay but all goes for $150+.....
Eighty-Nyne
Dec 10, 2008 10:22 PM
skateboard
Feb 9, 2007 11:23 AM
SPOONfed-Rex
Jan 19, 2007 02:42 AM
AaronJ
Dec 20, 2006 06:59 PM
NJE94Ghatch
Oct 27, 2006 08:27 AM
