I need new OEM Front and Rear LCA's
I have a 97 CX hatch and I need new front and rear LCA's. What are the best OEM LCA's to buy since I will be installing sway bars in the future. I need the OEM LCA that will accept sway bars like Suspension Techniques, thanks.
1.) why do you have to have OEM?
2.) The Suspension Techniques rear swaybar doesn't require special control arms as it bolts directly to the shock-mount hole of your existing arms.
3.) aftermarket LCAs for the rear are stronger, lighter, cheaper and prettier than OEM.
Any 94-01 Integra or 92-00 Civic front LCAs with work. If you plan to use an Si front sway, you need the Si front LCA. Your stock rear LCA will accept sway bar endlinks. Like Arch said, ST sways bars don't mount in stock locations.
si92hb
Oct 2, 2004 05:54 PM
