H22 into a crx
Old Jan 28, 2007 | 08:54 PM
BlueRex1020's Avatar
Default H22 into a crx
just like the title says guys...my friend offered me a mint h22 for 700 bucks and i'm really considering the deal. The problem is i'm only familiar with b series swaps n d series....i dont know too much about the h series. i know i'm going to be called dumb n told to search but i would like to hear some input from you guys. What tranny would i use? is there a cable tranny available or would i need to change to hydro? also mounts, where would i find h22 mounts for ef? n linkage, where would i get dat? n i'm guessing ill use a prelude ecu?
Old Jan 28, 2007 | 09:08 PM
yz125rider21's Avatar
Default Re: H22 into a crx (BlueRex1020)
hasport.com
and for tranny you can use b series as long as you get that adapter plate...just search for the plate...there where few threads here about using a b tranny on a h motor
Old Jan 28, 2007 | 09:15 PM
charlee's Avatar
Default Re: H22 into a crx (yz125rider21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yz125rider21 &raquo;</TD></TR><TR><TD CLASS="quote">
and for tranny you can use b series as long as you get that adapter plate...just search for the plate...there where few threads here about using a b tranny on a h motor</TD></TR></TABLE>
lol. tha h2b is way ahaed of him right now. but ya man, like he said, search and u WILL come up with a bunch of stuff.
Old Jan 28, 2007 | 10:08 PM
Default Re: H22 into a crx (charlee)
alright so i checked out hasport but h series mounts cost twice, or almost 3 times as much as b series mounts. do u guys know any other manufacture dat makes affordable or atleast cheaper h series mounts for ef?
Old Jan 28, 2007 | 11:30 PM
Hamstr323's Avatar
http://www.innovativemounts.com/
http://www.explicitspeedperformance.net/
Old Jan 29, 2007 | 06:47 AM
ESP-net
Guest
Posts: n/a
Default Re: H22 into a crx (Hamstr323)
http://www.ExplicitSpeedPerformance.net
*The only place that will do for your EF H22 needs*
The EF H22A motor mount kit is $474 shipped US...it includes the following and is damn steal...EF h22a motor mount kit, clutch cable/hydro conversion lever system, choice of H or D series alternator kits, detailed instructions.
If you want our Packaged Deal it's $780 shipped US and comes with everything above and our EF H22A traction bar system. Which is a must because the stock cross member will not work with any EF H22A swap. It replaces the stock cross member and has a lot advantages including preventing wheel hop and strengthening the front end.
Our kit clears the usdm hood...requires no firewall hitting...uses only 1 custom axle not 2...and uses the good Accord midshaft and integra axle combo that is not **** to problems like the other kits that use the Prelude midshaft and Prelude axle combo.... a lot of advantages and for the cost...it's a no brainer....
I have done the swap a few times now from A to Z I am here to assist as well through the swap...I wont leave you hanging and be like huh what?....
Old Jan 29, 2007 | 05:06 PM
alphajesse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yz125rider21 &raquo;</TD></TR><TR><TD CLASS="quote">hasport.com
The Hasport kit is not one of their best-engineered setups.
As far as transmissions, there are only hydraulic-clutch H- and F-series transmissions. If you have a quality shop do the fab work, you will find that a cable shifted h22 transmission feels awesome in an EF chassis... Compared to the same setup in my Prelude, the shifter is like butter. Blacktrax. Hasport.
With the Hasport kit, my ViS SiR-style hood is spaced up and it still rubs!
Old Jan 29, 2007 | 05:31 PM
2lude4u's Avatar
Default Re: H22 into a crx (alphajesse)
Here's a thread that shows my experience with an H22 swap using Hasport mounts, the FiberImages SiR hood cleared the engine:
https://honda-tech.com/zerothread?id=1646586
P.S. I had to part the car & still have several items that could make your swap easier- Shift linkage, Rywire harness, Hasport mounts if you want to go that route etc. Linked to in my sig.
vteczone
Nov 13, 2006 06:26 AM
f20bej1
Oct 29, 2006 11:17 AM
mikecivichb
Sep 1, 2005 02:28 PM
KNIVES
10
Jan 1, 2005 01:11 PM
streetspeed607
Apr 12, 2004 12:54 PM
