some mods for NA all motor nitrous
Old Jan 28, 2007 | 08:54 PM
drew338's Avatar
Default some mods for NA all motor nitrous
Does anyone have a mod list or some mods you would perfer for going NA like the order i should do it in also please? I have to learn more before i start my project Thanks (ive been searching also dont get me wrong)
Old Jan 28, 2007 | 09:01 PM
hu's Avatar
hu
First, start by checking the essential prelude link towards the top of the page. There is a lot of good info there.
Your build will depend on your goals and your pockets.
I always recommend sleeving your block. If not get Type S pistons as they are frm compatible.
Put some money into the head. Port and polish, cams, valves and valvetrain.
Dont forget the header. My personal favorite is SMSP. Top of the line headers are +$1,000.00.
If you plan to run nitrous I would recommend getting the pistons and piston rings heat treated.
Old Jan 28, 2007 | 09:02 PM
BlownH23a
Guest
Posts: n/a
rip out those connecting rods and get them shot peened, its cheap and if ur gonna do the pistons as recommended..it might as well be done anyways..
Old Jan 29, 2007 | 09:44 AM
drew338's Avatar
Default Re: (hu)
Thanks any more info on some good brands of parts that some of you have tested?
Old Jan 29, 2007 | 01:41 PM
Chuckles99SH's Avatar
Default Re: (drew338)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drew338 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks any more info on some good brands of parts that some of you have tested?</TD></TR></TABLE>
The fast and furious one and two played this weekend, you probably caught them both. You seem to have a goal in mind just because its cool, but you have no actual experience with building a motor to handle the negative effects of nitrous oxide through your motor. You need more knowledge before making these kinda of goals or your going to build a bomb under your hood. Just simply knowing the brands that will give you good results and wanting those brands is quite frankly retarded. You need to know more about engines before making pointless goals.
Old Jan 29, 2007 | 09:26 PM
drew338's Avatar
Default Re: (Chuckles99SH)
im not an idiot about engines. i just dont want to buy parts that arnt good theres so many different brands out there and i only know half them. i want to do it the right way first not go back and change things ya know.
Old Jan 29, 2007 | 09:27 PM
drew338's Avatar
im not puttin nitrous in right now i will eventually
Old Jan 29, 2007 | 10:11 PM
94Vtecluder's Avatar
Colder plugs, upgraded fuel rail, some tuning device to tune for nitrous.
Old Jan 29, 2007 | 11:01 PM
98vtec's Avatar
moderator emeritus
Default Re: (94Vtecluder)
why fuel rail? just curious....
and about dude saying you need knowledge first. As that may be true, you have to start somewhere. Obviously building a motor for the first time wont be like you are part of the nascar pit crew, but as long as you take your time and read about the ways to measure clearances, torque specs, etc....you will get the hand of it and you will possess knowledge of "how to" and not just something you have read how to do and therefore will have knowledge that i could bet 80% of the members of this forum dont have.
ANYWAY,
My suggestion to use it to not skimp out anywhere. You say you are not going to put nitrous on immediately so i would start out with a GOOD i/h/e setup, if you want to read info about the basic beginnings of a good setup then read this:
http://preludepower.com/forums...46845
It will give you a good idea of the differences between a mild (mostly show) setup and a setup that is purposeful in more than one aspect (show and power).
If your gonna be dealing with nitrous, I would highly recommend going with a program like hondata that has nitrous control as a tuning solution.
The FAQ of this forum holds LOTS of information that many people miss because they are just too lazy to search through them all. Starting there puts you ahead of MANY MANY members who you see posting questions that could be answered by reading the faq.
good luck.
Old Jan 29, 2007 | 11:32 PM
hu's Avatar
hu
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">why fuel rail? just curious....
Because you would want an aftermarket fuel pressure regulator to adjust accordingly!
Old Jan 29, 2007 | 11:41 PM
DCxMagus's Avatar
Default Re: some mods for NA all motor nitrous (drew338)
Save your money and start reading man, but if you must get your hands dirty BPI flow stacked intake and 2.5 exhaust is a good start, then a high end header and something to tune with.
also don't forget about suspension the lude is powerful enough stock, maybe you want to get that power to the wheels and threw the turns before you start adding more power to the car?
side note to Blake:Hey man hop on over to SCP quick when ya get a chance I'm looking for a RMF header and exhaust for my BB6 but Igot a few questions
Old Jan 30, 2007 | 12:11 AM
98vtec's Avatar
moderator emeritus
Default Re: (hu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hu &raquo;</TD></TR><TR><TD CLASS="quote">Because you would want an aftermarket fuel pressure regulator to adjust accordingly!</TD></TR></TABLE>
you cant put an aftermarket FPR on the stock fuel rail? It must be late or somethign.....oh....4:00am doing chemistry
Old Jan 30, 2007 | 04:59 AM
Iboot's Avatar
https://honda-tech.com/zerothread?id=180883
Old Jan 30, 2007 | 05:05 AM
mgags7's Avatar
you cant put an aftermarket FPR on the stock fuel rail? It must be late or somethign.....oh....4:00am doing chemistry </TD></TR></TABLE>
yes you can
oh and that sucks fer u
OP: Just get a turbo man, everyone knows they're the fastest. Don't listen to people like blake on here, they want you to go slow. Everyone knows, its the fastest who gets paid, and its the fastest who gets laid.
Old Jan 30, 2007 | 06:36 AM
drew338's Avatar
Default Re: (bb4ever)
thanks i am reading up on it a lot. i have to start somewhere right
Old Jan 30, 2007 | 08:19 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever &raquo;</TD></TR><TR><TD CLASS="quote">yes you can
OP: Just get a turbo man, everyone knows they're the fastest. Don't listen to people like blake on here, they want you to go slow. Everyone knows, its the fastest who gets paid, and its the fastest who gets laid.</TD></TR></TABLE>
you ***.
Old Jan 30, 2007 | 08:27 AM
skunked's Avatar
aftermarket fuel rail....lol that would be one of the last upgrades on my list.
and NO you don't need one to utilize an aftermarket fpr.
Old Jan 30, 2007 | 09:14 AM
BlownH23a
Guest
Posts: n/a
i got one off ebay(fpr)..how the hell do i install that ****!
http://cgi.ebay.com/ebaymotors...d=1,1
Old Jan 30, 2007 | 09:27 AM
mgags7's Avatar
did you really just buy a no-name fpr like that?
why would you do such a thing?
Old Jan 30, 2007 | 09:28 AM
98vtec's Avatar
moderator emeritus
Default Re: (BlownH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlownH23a &raquo;</TD></TR><TR><TD CLASS="quote">i got one off ebay(fpr)..how the hell do i install that ****!
http://cgi.ebay.com/ebaymotors...d=1,1</TD></TR></TABLE>
shoulda figured that out before you bought it dont yuh think?
I believe that FPR is inline with the fuel system. Meaning that it wont be bolting to the fuel rail. You will have to find a place to mount it and run a fuel line to and from it.
Old Jan 30, 2007 | 09:42 AM
BlownH23a
Guest
Posts: n/a
i bought it because of my running rich problem...i know its to suppliment the stock fpr..so i guess ill just splice it in right before the stocker and run a return line to the stocker..
i dont care about brand name items as long as they do what they are designed to do(it looks basically identical to the HKS one my friend had in his 700hp supra..if this one sucks ill buy a "brand name". worst that can happen is i lose 30 bucks or resell it to someone for 20.
Old Jan 30, 2007 | 09:47 AM
Hawkze_2.3's Avatar
Go ahead and buy the brand name FPR now. Save the hassle...
Old Jan 30, 2007 | 09:49 AM
BlownH23a
Guest
Posts: n/a
ill take it apart and take pics of the internals...then you guys can tell me if its any good or not...thanks
Old Jan 30, 2007 | 09:55 AM
Hawkze_2.3's Avatar
I'm sure all the parts will look fine at first glance, but I'd bet money that time will ruin the gauge mounted on there and the diaphragm inside. You'll probably have to torque down all the bolts properly anyway
Old Jan 30, 2007 | 10:04 AM
98vtec's Avatar
moderator emeritus
dude, you got it for 9 dollars. its not going to be the quality of HKS. Sorry to inform you.
