Part Number for Vehicle Speed Sensor
Old Jan 28, 2007 | 07:40 PM
dr_latino999's Avatar
Default Part Number for Vehicle Speed Sensor
I'm pondering to know if there are two different Vehicle Speed Sensor's available for the L3 DX transmission and the L3 SI transmission. To do this I need the part number for the sensor and if it is sold separately the VSS gear. And if you look it up, either way post up the part numbers. I've already checked the Transmission section of the parts guide on HondaPartsDeals.com
Old Jan 28, 2007 | 07:52 PM
Crx Jimmy's Avatar
Default Re: Part Number for Vehicle Speed Sensor (dr_latino999)
Are you taking about the actual vss in the cluster, or the part in the transmission that the cable goes in? if you are talking about the part in the transmission as far as I know most honda transmission are all the same you can swap speedo gears in d and b series cable or hydro transmissions
Old Jan 28, 2007 | 08:00 PM
Default Re: Part Number for Vehicle Speed Sensor (Crx Jimmy)
I'm sorry, I thought I was pretty clear but I'm in need of sleep. I'm talking the part that the cable plugs into the transmission. If the gear (Speedometer ring gear and the Gear at the end of the VSS) were the same on all Honda's, then speedometer calculations would come down to being calculated by the cluster if the final drive is changed from factory. I rather not ponder the inner workings of my speedometer and just go straight for part numbers on the transmission side if at all possible.
Old Jan 30, 2007 | 04:14 PM
Any comments / concerns / ideas?
Old Jan 30, 2007 | 04:37 PM
h224thgensedan's Avatar
after digging around i found your answer the speedo cable gear inside the transmission is the same part number
23820-PM1-000
what i found was different is the actual gear on the fd that the speedo reads off of
dx
41312-PL3-A00
si
41312-PL3-B00
ufakeit
Apr 23, 2008 10:21 PM
Heylookits shawn
Aug 16, 2007 10:40 AM
TMC_EF
Jul 16, 2007 10:37 PM
Runnerdown
Jul 6, 2007 04:05 AM
crexer
Nov 4, 2005 03:47 PM
