Electrical junkies please help...
I keep frying my ignition module. Ive replaced it 3 times now. When I put a new one in, itll start the car one time, then when I shut the car off, its fried. I have no idea what going on. Things Ive done to correct the problem: new cap and rotor, new plugs, new plug wires on the way, checked all grounds. Its not throwing any codes either. Anyone got a clue? Last hope before I get a Honda tech out to the house.
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
check the inside of the dizzy for bad insulation on the wiring. these cars are getting older, and i have seen it 2x before. the insulation is hard/brittle, and flakes off causing a short.
You mean just the wires sheathing ( insulation )? Have any ideas if that checks out ok? Going by memory they seemed to be ok, but ill get out there and give it a good look over.
