Will B16A work for swap?
Old Jan 28, 2007 | 06:32 PM
BlueLude84's Avatar
Default Will B16A work for swap?
Ok, as you guys know i drive my 84' Lude.
Now I got a suggestion earlier on swaping a B18A in with less difficulty then what i originaly wanted swapped in (F22).
I was comparing a B16A and a B18A, and it looks like the B16 costs less, and has more HP, so would this motor be just like swaping in a B18, or more difficult?
I guess the B18 does have more torque, but well.. what do you guys think?
-edit-
The B16A is also a smaller engine than the B18.
Old Jan 28, 2007 | 06:37 PM
roller3804's Avatar
just put a b20 in it and boost it.
Old Jan 28, 2007 | 06:53 PM
pinecone's Avatar
Default Re: Will B16A work for swap? (BlueLude84)
If you are comparing B series's, the B series in the Lude is the bastard child B series and has no similarities to the more popular b series.
Old Jan 28, 2007 | 10:40 PM
BlueLude84's Avatar
Default Re: Will B16A work for swap? (pinecone)
How can a B series have no similarities to the B series? lol
Im guessing you mean F series?
anyways, I just wanna know what B series engine would be the least difficult to swap into my Prelude.
Old Jan 28, 2007 | 11:02 PM
darkspector2.0's Avatar
they are both gonna be about the same amount of work, both need custom axles, both need custom mounts, and wiring.
Old Jan 29, 2007 | 05:02 AM
kulrevon's Avatar
Default Re: (darkspector2.0)
the b16, b18, and the crv b20. do not fit in the lude without modification.
They are not the same as b20 and b21 out of the lude.
And its true they have very few similarities.
Old Jan 29, 2007 | 05:14 AM
WhiteBB2's Avatar
Default Re: (kulrevon)
[QUOTE=BlueLude84Im guessing you mean F series?[/QUOTE]
No, He was right when he said B series.
Old Jan 29, 2007 | 07:22 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueLude84 &raquo;</TD></TR><TR><TD CLASS="quote">How can a B series have no similarities to the B series? lol
anyways, I just wanna know what B series engine would be the least difficult to swap into my Prelude.</TD></TR></TABLE>
Yes, the B16, B18 and B20s from Civics, Integras, CRVs, etc are totally different than the B20s and B21s from older Preludes.
For difficulty, the first set of B engines are all going to be roughly the same as a far as swapping. If you choose a VTEC engine you'll have more wiring and extra crap to worry about...but you'll have VTEC. Just choose if you want the higher-revving B16 or you want more low-end tq like with a B20 non-VTEC.
Old Jan 29, 2007 | 10:32 AM
for a 2nd gen I'd def go with a gsr motor
Old Jan 29, 2007 | 10:37 AM
rawNArsxS's Avatar
b20 vtec
Old Jan 29, 2007 | 10:52 AM
Default Re: (rawNAprelude)
the thing that sucks about that... is you have to get the motor, then build it. And after you've finished all of that... You can finally start fitting it in and getting all that custom stuff done.
I would stick with a motor that's good bang for the buck and has a little torque to push around your ride. plus the vtak
Frankie Flores
Apr 23, 2012 08:14 AM
civics4lyfe
Jan 21, 2009 08:47 PM
conan4
11
Nov 28, 2008 09:43 AM
usdmEHboy
Jan 4, 2008 05:13 AM
d1588hatchy
Jul 25, 2005 06:02 PM
