weld on aluminum nipples
im looking for some weldable aluminum nippled for welding to my valve cover. most people run the stainless steel lines to a breather but i was just going to run plastic tubing instead. anyone have a site where i could find some?
also ive been looking into getting a motorcycle radiator for the car and i i also needed to find some nipples to weld to some coolant plates that i plan on making to "size" down from the standard sized 1 1/2 or so to 3/4 to fit the motorcycle radiator.
if you want to use that plastic tubing, you are most likly going to have to buy a female aluminum NPT weld bung, then put a NPT brass barbed 90 degree fitting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic »</TD></TR><TR><TD CLASS="quote">if you want to use that plastic tubing, you are most likly going to have to buy a female aluminum NPT weld bung, then put a NPT brass barbed 90 degree fitting.
Yup, http://www.race-lines.com has all the stuff you'll need.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">
that place doesnt have much of anything
try here:
http://www.anplumbing.com/shop...!_Ons
</TD></TR></TABLE>that place doesnt have much of anything
try here:
Boostage
Jun 28, 2006 10:15 AM
