sohc to dohc
Old Jan 28, 2007 | 04:39 PM
pdx_503's Avatar
Default sohc to dohc
I already did a search. I have an 88 dx hatch with the stock sohc d15b motor and I was wondering if this would bolt directly onto my car. Or if its even worth it to invest the money. Let me know if the links dont work.
http://a.im.craigslist.org/VE/...Y.jpg
http://a.im.craigslist.org/u0/...b.jpg
http://d.im.craigslist.org/KX/...t.jpg
Old Jan 28, 2007 | 05:51 PM
sirtef9's Avatar
Default Re: sohc to dohc (pdx_503)
the ecu will go right in, youll need a dpfi to mpfi. wiring job, what motor you going with?
Old Jan 28, 2007 | 05:57 PM
pdx_503's Avatar
Default Re: sohc to dohc (sirtef9)
See my problem is that I dont have time to do a complete motor swap, which is ultimately what I should and need to do. But this is my daily driver, and my only transportation. I'm trying to do things here and there to add a few extra hp to the stock motor without doing the swap. I found this on craigslist and was wondering if its worth it. I'd be putting it on the stock d15b2 motor, just not sure if I need to replace some other things before putting it on or do I just slap it on and call it good.
Old Jan 28, 2007 | 06:04 PM
sirtef9's Avatar
I see , just a ecu upgrade? Go for the pr4 Ls...never done it but it will have better maps,,
Not2farFromtypeR
Jul 25, 2006 01:34 PM
Blanket Jackson
Apr 18, 2006 01:49 PM
VolcomCivicGuy
Apr 3, 2003 11:36 PM
92civicJDM
Aug 31, 2002 08:36 PM
