need help with jdm fog wiring
Whats up guys, i just recieved the jdm rear fog for my del sol and i got the switch that comes with it.. no harness, just a pigtail
The switch is black if that helps, its got 5 wires coming out of it. I know obviously i need a relay.. Im not a noob, but b4 i take out the multimeter i figured i would ask if anyone has done this mod before, using the switch.? Any help is appreciated. -Please dont tell me to search, i did already. I found one in the ITR forum using a 5 wire switch but the drawing looked like my 5 yr old cousin drew it and wasnt very informative. Thanks again
Was this the post? The diagram is not hard to read and it's very understandable.
https://honda-tech.com/zerothread?id=105247
If you can't get past the drawing, I can make one tomorrow for you. It will contain the same info, less colorful I suppose.
yeah that was it.. the reason why i say its kinda hard to understand is bc the way he labeled the wire colors on the plug.. he labeled 2 blacks and i only see 1.. plus the pigtail on my plug is all red wire so wire location (pin wise) is also important, which is also hard to makeout from his description
All the wires can't all be red. There are two black wires in the pic. Judging from the first pic of the switch plug, you can deduce which wires go where on your pigtail.
1. Red/black = goes to fuse box (for EG, it's fuse 19)
2. Red/yellow = to relay
3. Black = ground
4. Black = ground
5. Red/black = goes to fuse box (fuse 19)
Fuse 19 is for the interior light I believe
all the wires on my pigtail are red.. why? i dont know the idiot that repinned it decided to get cheap and use all red wire. but thanks man i appreciate it.
one last question, my plug has 2 rows 4 wires straight across one row, and the 5 wire is in the last position 2nd row. (i also couldnt see the 2nd black wire in the pic) is that plug the same way? my comp sucks
guywitaDA
Apr 17, 2007 05:04 PM
JDMTEG98
Sep 1, 2002 07:04 AM
