If going from 14" to 17" do I need to raise car or change camber?
I want to put 17" rims on my 95 civic ex and just wanted to know if I need new suspension to raise the car or will it be fine. Also, do I have to change the cambers at all? I dont really want to raise the car or camber so how much larger rims can I get withouth having to do either.
also, what would be good tire sizes for 17" ??
Thanks,
Thanks,
You will need to get 205/40-17 tires. It's 3.6 percent larger than your stock size in diameter, so they are quite huge. They will throw off your speedometer and odometer by that percentage. They might also rub; you'll have to try them out and see. Unfortunately, that's the smallest commonly-available 17" size, so that's what you're stuck with. I wouldn't get 17" wheels for a pre-'96 Civic for this reason. On your car, you would be much better off going no larger than 16" (205/40-16 fits nicely) or 15" (with 195/50-15 tires).
Drewsgotshoes
Feb 18, 2017 08:30 PM
