reseting computer on a 97
Old Jan 28, 2007 | 11:18 AM
pr3ludeboi's Avatar
Default reseting computer on a 97 prelude type SH
ok so i wanted street glow and a friend was selling his i thought maybe i should let pros do it but he said he did his and was only charging me 50 for everything so i said ok anyways we hooked up the toggle switch and all that **** he had to mess with some fuses i didn't unhook the battery so the computer was still on i'm guessing the ending result is i have a toggle switch and lights however my windows don't work my gear shift is tight and won't go into park without cutting it off and my cdplayer won't play and the clock is off i'm guessing it's cuz he unhooked fuses while the computer was on and now i need to reset it cuz my freaking speedometer doesn't even work and i really want to drive my car its an addiction SO.... if anyone can plz anwser my question i would really appreciate it
Modified by pr3ludeboi at 12:46 PM 1/28/2007
Old Jan 28, 2007 | 12:45 PM
honda_andy's Avatar
first recommendation, use periods and commas once in a while.
Old Jan 28, 2007 | 01:07 PM
pr3ludeboi's Avatar
Default Re: (honda_andy)
thanks for the help.....
Old Jan 28, 2007 | 01:15 PM
thegeorge613's Avatar
Default Re: reseting computer on a 97 prelude type SH (pr3ludeboi)
Take off the negative terminal on the battery for a couple of minutes and put it back on. That's how you reset an ECU.
General rule of thumb, always take off the negative terminal on the battery when workign on something involoving electronics.
Old Jan 28, 2007 | 01:18 PM
pr3ludeboi's Avatar
Default Re: reseting computer on a 97 prelude type SH (thegeorge613)
i took both off for about 15 mins and the check engine light still comes on. It has a tight gear shift i'm guessing the sensor for the transmission isn't working i know the abs isn't working and the windows still don't work can the dealer fix this problem or is there another way?
Old Jan 28, 2007 | 01:39 PM
pr3ludeboi's Avatar
bump
Old Jan 28, 2007 | 03:54 PM
ethereal2pt2's Avatar
you said it yourself, maybe he unhooked a fuse? so then retrace your steps and hook back what he undid. or maybe he blew something? my friend was messing around with his wires tryna get some lights in his car and he short circuited the damn thing. none of the lights nd shiz came on at all. if you don't know what you're doing.. get someone who does. good luck.
Old Jan 28, 2007 | 07:35 PM
TDCTyler's Avatar
you guys want to install sreetglow on my car?
Old Jan 29, 2007 | 03:16 AM
1GPlusSH's Avatar
Default Re: reseting computer on a 97 prelude type SH (spOolin97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spOolin97 &raquo;</TD></TR><TR><TD CLASS="quote">you guys want to install sreetglow on my car? </TD></TR></TABLE>
too funny
soupE__
Jun 25, 2011 10:06 PM
daffy_1
Aug 20, 2007 09:11 PM
hb_guy
Oct 7, 2005 04:05 PM
asianalbutt
Sep 15, 2005 06:24 PM
ATS*Mark
16
Sep 2, 2004 05:49 PM
