Exedy Flywheel
Old May 16, 2002 | 08:41 PM
Peter Lim 1110's Avatar
Default Exedy Flywheel
Does anyone know how much Exedy flywheels weigh?
and what about toda? any difference in quality?
I've heard good things about the toda and that there is no problems with it.. but what about the exedy does it have any known problems with the starter teeth
[Modified by Peter Lim 1110, 5:42 AM 5/17/2002]
[Modified by Peter Lim 1110, 5:44 AM 5/17/2002]
Old May 16, 2002 | 10:22 PM
sgT's Avatar
sgT
Default Re: Exedy Flywheel (Peter Lim 1110)
get a fidanza aluminum
Old May 16, 2002 | 10:24 PM
Chris's Avatar
Default Re: Exedy Flywheel (sgT)
Thats my plan as well.
Old May 16, 2002 | 10:56 PM
Austin's Avatar
Default Re: Exedy Flywheel (Chris)
Hmmm....sounds familiar ...retail around $430, can usually be had for $310 shipped, or if you have a really good hookup $287 shipped
Austin
Old May 17, 2002 | 12:47 AM
AJ PwR's Avatar
They weigh 4.1 kg.
Get Spoon instead cuz they are the lightest (no holes) chromoly flywheel on the market.
Old May 17, 2002 | 12:58 AM
Type-Rare#1248's Avatar
Default Re: Exedy Flywheel (AJ PwR)
They weigh 4.1 kg.
how about toda??
Old May 17, 2002 | 09:04 AM
Nick248's Avatar
Clutchmaster flywheels are Fidanza flywheels.
Fisanza makes them look pretty for them.
-nick
Old May 17, 2002 | 09:29 AM
AJ PwR's Avatar
Default Re: Exedy Flywheel (Type-Rare#1248)
Todas are lighter they weigh 3.9kg but more expensive.
Old May 17, 2002 | 09:43 AM
RICHJ's Avatar
Cusco are 3.9Kg also, chromoly with holes. Goes on tomorrow with metal disc and cover.
Bling!
[Modified by HardHead42, 6:43 PM 5/17/2002]
[Modified by HardHead42, 6:46 PM 5/17/2002]
Old May 17, 2002 | 10:43 AM
Blade's Avatar
New User
The Toda flywheel is 4.1kg and it has better weight distribution than spoon, so even though the weight is the same, it responds very differently.
Old May 17, 2002 | 10:49 AM
B2FiNiTY's Avatar
Default Re: Exedy Flywheel (Blade)
Why do you say the spoon has worse weight distribution?
Old May 17, 2002 | 11:04 AM
Black R's Avatar
25 Year Member
..... I just put on toda clutch and flywheel recently. Better than stock.
Next time, I'll try the lightest flyweel I can get my hands on (~6lbs).
I'd suggest you do the same for the $.....
Old May 17, 2002 | 11:14 AM
RTW DC2R's Avatar
Default Re: Exedy Flywheel (Black R)
I heard that you shouldnt go much lighter than 9 or 10lbs....so im sticking to spoon 10.80lbs
Old May 17, 2002 | 11:19 AM
SwiftTypeR's Avatar
New User
Default Re: Exedy Flywheel (RTW DC2)
shouldnt go lighter then 9-10 lbs, why? i have a comptech 6.75lb fw which rox! i guess it would depend on your set up, but im sticking with all motor and imo the lighter the better.
Old May 17, 2002 | 11:21 AM
Black R's Avatar
25 Year Member
Default Re: Exedy Flywheel (SwiftTypeR)
.....my sentiments exactly.
Old May 17, 2002 | 11:22 AM
RTW DC2R's Avatar
i think if you are more into road courses/auto X, then lighter is better. but for drag, I think u need to have a little more rotating mass for torque off the line. something to that affect, from what ive heard. im by far no expert.
Old May 17, 2002 | 11:24 AM
Black R's Avatar
25 Year Member
that makes sense, but really it should be an advantage b/c you have to rev a little higher to start off the line. that's fine b/c you are closer to being higher (where these motors make power) in the redline.
Anyone EXPERIENCE a downside to a light flywheel on a honda motor?
project dc2
Jan 26, 2007 07:09 PM
EKen9
May 13, 2004 07:45 AM
quick108
Jul 15, 2002 02:12 PM
Isaac
Apr 3, 2002 01:48 PM
LoudAccord
Jan 8, 2002 08:40 PM
