98 Accord Brake pad recommendations???
Lx 5spd pretty much stock, it has cross drilled rotors, no idea what kind of pads are on it right now. I just know they need to be replaced and they create lots of dust
. Any suggestions for a street car that is not ever raced?? And where should i buy these pads as well? Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head »</TD></TR><TR><TD CLASS="quote">rotor: oem or brembo blanks
pad: ebc green, oem, axxis ulitmate(alots of dust tho)</TD></TR></TABLE>
Not sure what you're doing with cross drilled rotors. They're just going to create more dust.
The rotors were already on the car, i don't want to replace anything that doesn't need replacing yet
. I heard EBC gives off less dust, is that true??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chomorro »</TD></TR><TR><TD CLASS="quote">The rotors were already on the car, i don't want to replace anything that doesn't need replacing yet
. I heard EBC gives off less dust, is that true??</TD></TR></TABLE>
same if not less than OEM, ebc green.
. I heard EBC gives off less dust, is that true??</TD></TR></TABLE>same if not less than OEM, ebc green.
I have had good luck with Wagner Thermal Quiet, they don't seem to be so hard a compound as the honda pads because they don't cause glazing of the rotor.
Haven't seen much dusting from them either.
But they aren't much less money than the OEM pads
Lowski
Aug 5, 2020 09:11 AM
03blkaccord
Jan 19, 2011 05:59 PM
full Circling
Jul 10, 2004 01:30 PM
