When to shift?
Let's say you have a second gen 5 series b16a. Your redline would be like 7900, but the motor stops getting anymore power at 7800 rpm. Are you supposed to drive it to 7900 or are you supposed to shift at 7800 rpm, and why?
lets get this straight
no such thing as a gen 5 b16.
you mean you have a 5th gen civic with a b16? is the b16 first or second gen?
and with stock intake, header and exhaust i would shift about 7700
once you start opening it up with intake header and exhaust its good to go to 8,000 and above
Vanilla what all do you have done to you b16? the reason I asked is because my friends Del Sol ( has a B16) Produces Hp all the way to 9K, it just gets there so damn quick.
I was just wondering in general of when you should shift a motor compared to stock specs. I don't even have a b16a motor. I am putting in my b20vtec this weekend if I can get the JE 11.0:1 pistons in.
I understand why Kamin misunderstood, not everyone takes time to read each post over and over to completely understand it, jeez.
shift with what you feel comfortable, but understand what a higher rev can do to your engine overtime.
Kinda stealing this post (sorry). But to stay in a powerband is it better to rev higher (even if you don't make power that high) so that you can drop into the powerband. Or to shift where you stop making power and have to bring it back into the powerband?
Did we really need to know you had a "5" series B16? No. That's what made it confusing.
Take it to the dyno and find where your car (b/c every motor is diff.) stops
making power. That should tell you exactly where to shift.
i guess Kamin is fucken blind to see what you wrote..he needs to read more carefully....and when your engine loses power at that point...you should try shifting a little bit earlier..and u shouldnt redline because it slows your car down
[Modified by RICErocket03, 6:01 AM 5/17/2002]
his post was confusing. i was just trying to clarify it for him if he didnt know. apparently he does.
You dont shift when it stops making power, you shift at redline. LIke one person said, you keep it in the powerband longer, making more power for longer, that means you go faster.
Dont flame people with lots of posts, when you only have a few. just a tip.
