f23 engine swap cl type s
Old Jan 27, 2007 | 07:41 PM
raleighaccord's Avatar
Default f23 engine swap cl type s
I am looking to gain more power and still have some reliability. I put a f23a5 in my 2000 accord 2 door figuring it would be better for a turbo. Is it better? How hard would it be to do a acura cl type s swap, and what would I need for it? Thanks
Old Jan 27, 2007 | 08:39 PM
cantaffordaccord's Avatar
Default Re: f23 engine swap cl type s (raleighaccord)
well if I were you I would go for at the least pistons and rods those alone are about 1200 clams
plus annother 12-1500 for a nice standalone
plus annother 1500-3k for a turbo kit witch if i were to do I would peice together my own kit inorder to satisfy my needs/ability to expand power
Old Jan 28, 2007 | 04:07 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raleighaccord &raquo;</TD></TR><TR><TD CLASS="quote">I am looking to gain more power and still have some reliability. I put a f23a5 in my 2000 accord 2 door figuring it would be better for a turbo. Is it better? How hard would it be to do a acura cl type s swap, and what would I need for it? Thanks</TD></TR></TABLE>
i don't get it your coupe already came with f23a1/4 which is the vtec version of the f23 and you want to swap in the non-vtec dx,vp motor?
Old Jan 28, 2007 | 07:00 AM
oodie's Avatar
Default Re: f23 engine swap cl type s (iam7head)
That's basically the same motor you have now
Old Jan 28, 2007 | 11:05 AM
philadd's Avatar
Default Re: f23 engine swap cl type s (oodie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oodie &raquo;</TD></TR><TR><TD CLASS="quote">That's basically the same motor you have now</TD></TR></TABLE>
No, it's less powerful than the motor he started with. And, he already had the F23A5 installed.
To be blunt, it's not better. The primary weakness of the F23 motor is going to be the ringlands, and that goes for all variations of the motor. I don't think you're going to want to try a CL-S swap, mostly because you're starting with a 4-cyl. When you compare the I4 engine bay to the V6 engine bay, everything is on opposite sides. Everything. It would be better/easier/cheaper to trade your car in for a V6 model.
Old Jan 28, 2007 | 07:00 PM
Default f23 ringlands weak?
I appreciate the help. What can I do correct that on a 2000 dollar budget? Recommend any parts place or will f22 parts work? Thanks alot, just want to make sure I dont waste my money when I order the turbonetic t3/t4 turbo kit.
Old Jan 28, 2007 | 08:15 PM
philadd's Avatar
Default Re: f23 ringlands weak? (raleighaccord)
In the Accord FAQ you will various links to online stores. A set of forged pistons will cure the ringland problem. Get a nice of rods to go with the pistons, and you should be set for a good amount of power.
Modified by philadd at 1:39 PM 1/29/2007
Flatbush_Best97
Nov 19, 2021 08:45 AM
dapcivicek
Acura TL, RL & ZDX
20
Sep 7, 2016 01:42 PM
thebiglou
Apr 7, 2007 02:08 PM
k24a4kid
36
Dec 29, 2004 12:43 AM
