Short cluch pedal movement?? Help?
Old Jan 27, 2007 | 04:56 PM
IamPhil's Avatar
Default Short cluch pedal movement?? Help?
I just got the master and slave cylinders on the clutch of my 96 GSR replaced and the fluid bleed. But now... my pedal doesn't spring back as high as it used to before the mechanic replaced everything. Is this normal? Should I keep driving like this? Is there a way I can adjust how high the pedal returns?
Old Jan 28, 2007 | 05:07 PM
IamPhil's Avatar
Default Re: Short cluch pedal movement?? Help? (IamPhil)
I'm starting not to like this mechanic... -_- the rubber on top of the clutch pedal ripped off..
Old Jan 28, 2007 | 05:23 PM
thatwhiteguy's Avatar
rebleed it, takes like 10 mins, maybe he did a lazy job of the bleeding. double check to make sure the new mcc and scc's actually look NEW.
hj2
Apr 30, 2009 09:38 AM
The Droogan Leader
Oct 6, 2006 12:05 PM
gsr1289
Aug 22, 2006 07:11 PM
black_bb1
Jul 14, 2006 07:22 AM
TeamTooQuick
Aug 28, 2003 08:07 PM
