All motor Gurus...please help!
yo man..mind if i ask another question.....what you think of the following combo: 81.5mm gsr block, b16a2 head, ctr pistons, ls crank and rods, arp head studs and rod bolts..itr oil pump.....im assuming i will have to clay with the pct pistons...just wanted your .02 on it
Get different pistons if you are planning on running it on pump. No need for the super high compression with shitty pump gas. Seems like you still have alot of stuff missing tho.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Professor15 »</TD></TR><TR><TD CLASS="quote">. Seems like you still have alot of stuff missing tho.</TD></TR></TABLE>
such as?
i certainly appreciate the input...i know 12:1 is a lil high, but i bet it will be responsive...we get 93 at the pump here....which is ok....and im sure it will smoke a bit....the roommate just wants it to have some kick to it....
such as?
