shot peened rods
Old Jan 27, 2007 | 04:01 PM
sasinorm01's Avatar
Default shot peened rods
i have been told that rods that have polished side beams, and the surface has been shot peened that they are also good for mild boosted engines ..has anyone used shot peened rods before and is this true
Old Jan 27, 2007 | 04:23 PM
Got_soy's Avatar
Default Re: shot peened rods (sasinorm01)
only if they are free, d series rods are tiny.
Old Jan 27, 2007 | 04:31 PM
bag's Avatar
bag
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sasinorm01 &raquo;</TD></TR><TR><TD CLASS="quote">i have been told that rods that have polished side beams, and the surface has been shot peened that they are also good for mild boosted engines ..has anyone used shot peened rods before and is this true
what are you even talking about. brand? engine? what?
Old Jan 27, 2007 | 06:49 PM
sasinorm01's Avatar
http://cgi.ebay.com/ebaymotors...=true ....... check this out.... was going to buy these then get some vitira pistons.....in a d16z6 daily driver
Old Jan 27, 2007 | 08:20 PM
bag's Avatar
bag
Default Re: (sasinorm01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sasinorm01 &raquo;</TD></TR><TR><TD CLASS="quote">http://cgi.ebay.com/ebaymotors...=true ....... check this out.... was going to buy these then get some vitira pistons.....in a d16z6 daily driver</TD></TR></TABLE>
ok i got it..
yeah those are stock d16 rods that have been treated..The shotpeening does make them alot harder but still i dont know if they would match the vitara pistons which ive seen go for 400-500whp with no problem. how much hp you trying to get? if its like under 300whp you'd be fine with these rods
Old Jan 27, 2007 | 08:31 PM
Tippyman's Avatar
Default Re: (bag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bag &raquo;</TD></TR><TR><TD CLASS="quote">
ok i got it..
yeah those are stock d16 rods that have been treated..The shotpeening does make them alot harder but still i dont know if they would match the vitara pistons which ive seen go for 400-500whp with no problem. how much hp you trying to get? if its like under 300whp you'd be fine with these rods</TD></TR></TABLE>
300 hp on "polished and shotpeened" ebay rods? Go ahead.
Post pix of the hole in your block when you're done.
Old Jan 27, 2007 | 08:49 PM
FIGARILA's Avatar
Default Re: (bag)
why not just buy some d16a1 rods alot cheaper and stronger then a6 or z6 rods? i don't know about the 300 HP #
Old Jan 27, 2007 | 08:50 PM
bag's Avatar
bag
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
Post pix of the hole in your block when you're done.</TD></TR></TABLE>
you dont have a clue what you're talking about...Why do you call it an ebay rod? i dont understand,this isnt some $10 coilovers or $5 shifter...These are oem stock honda rods that have been polished,shotpeened,and have had arp rod bolts fitted...So you know 250whp is possible on bone stock rods,,so why is it so hard to believe that 300whp isnt possible with shotpeened rods and susuki vitara pistons? you have no experience obviously,but I do.
to the post right above d16a1 rods arent stronger,,maybe you meant to say use some machined b18a/b rods??? cause that's another option for the og poster and god knows the b-series rods are alot more stout from honda.
Old Jan 27, 2007 | 09:00 PM
FIGARILA's Avatar
Default Re: (bag)
to the post right above d16a1 rods arent stronger.....</TD></TR></TABLE>
perhaps, but they sure are thicker then stock a6 rods.
Old Jan 27, 2007 | 09:03 PM
Tippyman's Avatar
Default Re: (bag)
I would not trust anything so vital to the health of my motor to ebay sellers. You don't know what the fu<U></U>ck the seller did to those rods. He coulda just wiped them down with simple green and sold them. Just get some tuner toy rods for $90 more and know what you're getting. Plus they're a hell of alot stronger.
Vitara's have been proven, these rods most cerainly have not.
Old Jan 27, 2007 | 09:06 PM
slow_ls's Avatar
Just get some tuner toys rods for $225 and call it a day. Don't be cheap or you will could pay badly.
Tippyman's Avatar
Default Re: (slow_ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow_ls &raquo;</TD></TR><TR><TD CLASS="quote">Just get some tuner toys rods for $225 and call it a day. Don't be cheap or you will could pay badly.</TD></TR></TABLE>
Old Jan 27, 2007 | 09:35 PM
Got_soy's Avatar
Ebay will F uck you like a cheap *****. trust me. it sucks ****. even strenthed rods wonth hamdle that much D16 rods are tiny. IF you are going to upgrade get so TT rods atleast . IF not go for eagles
Old Jan 28, 2007 | 04:33 AM
Sikocivic's Avatar
Shot peening rods does not make them stronger( I was told this by a company that does this work) it eliminates surface defects that can cause the part to fail. They Magnaflux them to check for cracks and then blast them. This a quote from Peening Technologies:
"Shot peening is a cold working process used to increase the fatigue life of metal parts. Parts are bombarded with round steel, glass, or ceramic shot under controlled conditions to induce a stressed surface layer in compression. This surface layer inhibits the formation of tiny surface cracks which give way to fatigue failure."
Old Jan 28, 2007 | 05:15 AM
sasinorm01's Avatar
"tuner toy rods" ..this may be a dumb question but what
are those
Old Jan 28, 2007 | 06:29 AM
Tippyman's Avatar
It's s company that produces tuner parts, including connecting rods.
http://www.tunertoys.com
Old Jan 28, 2007 | 07:44 AM
bag's Avatar
bag
Default Re: shot peened rods (Sikocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sikocivic &raquo;</TD></TR><TR><TD CLASS="quote">Shot peening rods does not make them stronger
no one said it does.
Old Jan 28, 2007 | 07:47 AM
crxnj's Avatar
you might not even need to waste money on upgraded rods or pistons..how much power are you looking to get?
Old Jan 28, 2007 | 05:20 PM
sasinorm01's Avatar
hmm looking for 220-240 whp
Old Jan 28, 2007 | 05:22 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sasinorm01 &raquo;</TD></TR><TR><TD CLASS="quote">hmm looking for 220-240 whp </TD></TR></TABLE>
****, use stock rods. So long as you maintain stock redline and get it tuned properly you should be able to make a D16A6 hit 220 no problem.
Old Jan 28, 2007 | 05:29 PM
sasinorm01's Avatar
hmm ok ....so stock rods and pistons would be safe to use.......
Old Jan 28, 2007 | 05:36 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sasinorm01 &raquo;</TD></TR><TR><TD CLASS="quote">hmm ok ....so stock rods and pistons would be safe to use.......</TD></TR></TABLE>
Yes. A local tuner around here tunes stock d-series bottom ends to 240-250 all the time.
I wouldn't feel safe driving it around, but it'd definiately been proven to work. I need a little more security, lol.
Old Jan 29, 2007 | 04:34 AM
crxnj's Avatar
yeah its fine on a really really good tune and atleast 91 octane all the time. its all up to you though ,if you have the extra money for forged pistons and rods,30 overbore and honing then do it..this way you can up the boost whenever you want and wont be limited to around 200-240whp,,but more like 400whp+
sasinorm01
Oct 19, 2006 07:44 PM
fastcivicboy
Apr 10, 2005 05:30 AM
KillerBee18
Mar 31, 2004 04:12 PM
B20 BEAST
Apr 24, 2003 06:58 PM
