MPFI Hose hook ups
I have all the coolant/vacuum lines hooked up but can't find where 2 of them go. there are 2 plugs on the si manifold for hoses. 1 is on the bottom of the throttle body under the intake inlet. the other one is by the #4 injector under the fuel rail by the block.
any clue where these go?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinger »</TD></TR><TR><TD CLASS="quote"> its on the intake manifold by the block by injector #4..... that picture doesnt show me anything.</TD></TR></TABLE>
lol what are you talking about? can you circle it on the picture i posted and post that up? are you talking about the hose from the valve cover to the intake?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n »</TD></TR><TR><TD CLASS="quote">
lol what are you talking about? can you circle it on the picture i posted and post that up? are you talking about the hose from the valve cover to the intake?</TD></TR></TABLE>
it isnt picture in that picture.
that is the 1 by the block that I was talking about. the other one is below the throttle body inlet. it looks like it might be D on that 1 pic but I can't tell.
thats a coolant line.. you need the C shaped coolant line from the mpfi engine. or buy a new one. lol odnt hook that up to vacuum or your going to blow tons of smoke out your engine. D on that picture should hook up to the first vacuum inlet on the throttle body .. you can see that one in the picture i posted.
ok, i replaced the coolant hose.
but I still need the one for under the throttle body inlet. i'll try to take a picture of it later. It wasnt pictured in any of the pics in this thread.
Ahhhh.......A pictures worth a thousand posts!! The nipple in question now is for coolant. There is a choke under the TB that runs from front to back. You pull coolant from the intake mani into it and run coolant out of it into the IACV or Idle air control valve. You will see this on the back of the mani. Run the hose to the left side of the IACV. Hope this helps!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88EF9 »</TD></TR><TR><TD CLASS="quote">good luck im doing mine soon</TD></TR></TABLE>
good luck with yours ... they arent hard (wiring is easy), I just wish there was more info on the vacuum lines and coolant hoses.
gnccracer18
14
Sep 16, 2008 03:53 PM
