91 hatch
Old Jan 27, 2007 | 02:20 PM
mugen_tuner's Avatar
Default 91 hatch
is the stock d15 in 91 ef hatch able to handle turbo? curious cause found a complete bolt on kit on ebay for 1,000 just wanted to see if it was worth it
Old Jan 27, 2007 | 02:26 PM
Bejita's Avatar
You need to do a lot of research bro.....Search is your friend!!
Old Jan 27, 2007 | 02:35 PM
Default Re: (Bejita)
im aware i just dont know if it would be safe ive heard from a couple of people it can handle 3-5 lbs of boost i just dont see alot of them boosted though
Old Jan 27, 2007 | 02:40 PM
e jay one's Avatar
Default Re: (mugen_tuner)
im sure you could boost it but the thing is your stock d15 is dpfi as in only 2 fuel injectors. now when you turbo you need more fuel thats why when you turbo a motor you get bigger injectors. and your motor only has 2 so it wont be able to supply enough fuel. but it still can be done.
Old Jan 27, 2007 | 02:48 PM
Default Re: (e jay one)
oh yeah i will be getting a different intake manifold probably from an si but u think that would work huh
Old Jan 27, 2007 | 02:53 PM
SupraRXZ's Avatar
dont waste your money, you'd get better gains if you swaped out your motor
Old Jan 27, 2007 | 05:27 PM
viciousef9's Avatar
Default Re: 91 hatch (mugen_tuner)
dont buy any turbo kit on ebay. yes the d15 can handle turbo but why would you turbo that motor. if you want to stay sohc the turbo the z6 or the zc its alot better and you dont have to worry about the bullshit *** intake manifold swap your gonna want to do later if your not talkin about the d15b vtec, which i think your not. do more research on turbo's and motors berforeyou waste money in a lost cause.
Old Jan 29, 2007 | 09:41 AM
obd0crxMT's Avatar
Default Re: 91 hatch (viciousef9)
boost it until it blows in the mean time find a b18a and when the d gows swap this allows for maximum fun and minimum waste of time
Old Jan 29, 2007 | 12:57 PM
sanimalp's Avatar
$cat /dev/urandom
for $1000, you could almost buy a b16 from hmotors.. but thats only the beginning.. you could get a d15b2 for $450 and have plenty of money left over, and 20 more horsepower, vtec, multipoint fuel injection, and a stronger engine all around. then if you spent your leftover money on a si trans, you would have a hot hatch for less than a grand.. if you are poor, as i am, its the best thing to do.
going turbo, while fun, is expensive. first you have the turbo kit. the quality of an ebay kit is questionable at best, so you can try to peice one together. junkyard turbo's usually need a rebuild on the order of $300, and you need a manifold, blow off valve, a wastegate(internal or external?), and a way to control boost so you only make the 5 lbs your engine can handle. then you need a pm6 ecu(which you do not have in the car) chipped to handle boost correctly, and then it needs to be tuned so you dont blow it up. in your case, you also need to do a multipoint conversion because the 2 baby injectors in the dpfi setup are not up to the task of a boosted setup.
cliffs: swap the engine with something you can afford on hmotors. d15b2 is a good choice. $450 for the swap, and its plug and play with the exception of vtec.
ks87
Jun 10, 2012 06:47 PM
Tommyguns
31
Jan 17, 2007 07:53 PM
RenzoDaPlayboi
Jul 5, 2005 03:44 AM
bbrian
Dec 16, 2004 04:42 AM
Sirex
Nov 11, 2002 07:00 AM
