Blinkers not working right after Steering wheel install
Old Jan 27, 2007 | 12:57 PM
iheartintegras's Avatar
Default Blinkers not working right after Steering wheel install
After putting on my jdm itr wheel, either my blinkers will turn off by turning my wheel only a tiny bit or they'll stay on after turning and won't turn off. Anyone had this problem?
Old Jan 27, 2007 | 01:11 PM
diversegsr's Avatar
Default Re: Blinkers not working right after Steering wheel install (iheartintegras)
i think was a common problem....but cant remember the outcome and/or the rememdy
Old Jan 27, 2007 | 01:22 PM
hopefully it's fixable =/
Old Jan 27, 2007 | 02:45 PM
Daammnn's Avatar
i have a after market steering wheel and so does my friend same thing happens, i kinda just got use to it..i don't know what it is.hah
Old Jan 28, 2007 | 12:29 PM
up
Old Jan 30, 2007 | 11:38 PM
bump
Old Jan 31, 2007 | 12:00 AM
ImportMotorSpec's Avatar
Default Re: (iheartintegras)
There are little trips and catches (dont know what else to call them) that allows the lever to stay on during a turn and release after the wheel went past the engagement point. Don't know if you could find a diagram on the order of the pieces, but most likely they are messed up.
I think there are a few plastic ones and then a metal one.
Old Jan 31, 2007 | 12:14 AM
suzawa94's Avatar
Default Re: (ImportMotorSpec)
the cancelling switch is usually triggered by the clockspring (airbag component). if you ever removed a clockspring, you would notice a sort of tab that cancels or switches off the turn signal tab.
double check to see that when you installed the steering wheel you did not expletive up any thing abvious (like the cancelling tabs). if not the only other thing is that the clockspring cancelling mechanism is broken, in which (probably) you would have to replace the clockspring assembly. i don't think the cancelling device on the clockspring has its own part #.
Synapz
Honda Civic (2001 - 2005)
15
Jul 26, 2007 12:08 PM
LBCek9
Dec 22, 2005 08:40 PM
Cloner
Nov 18, 2005 12:37 PM
egvtec
18
Nov 11, 2005 03:35 PM
EARLdaSQUIRREL
Jan 16, 2004 06:15 PM
