90mm throtle body on H23 vtec?
Old Jan 27, 2007 | 10:11 AM
meanshyguy's Avatar
Default 90mm throtle body on H23 vtec?
90mm throtle body, I got it from an Infinity Q45, they say it's possible to hook it up to an H22 Intake manifold. How do I do it?
Old Jan 27, 2007 | 12:15 PM
snowblind7x's Avatar
Default Re: 90mm throtle body on H23 vtec? (meanshyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meanshyguy &raquo;</TD></TR><TR><TD CLASS="quote">90mm throtle body, I got it from an Infinity Q45, they say it's possible to hook it up to an H22 Intake manifold. How do I do it?</TD></TR></TABLE>
and what is the point of such a monstrous sized tb...?
Old Jan 27, 2007 | 12:17 PM
ninja 6's Avatar
Default Re: 90mm throtle body on H23 vtec? (snowblind7x)
that is insanely oversized for any mild build on an h-series
besides you'd have to build a custom intake mani to match the tb.
Old Jan 27, 2007 | 01:02 PM
98vtec's Avatar
moderator emeritus
Default Re: 90mm throtle body on H23 vtec? (ap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ap &raquo;</TD></TR><TR><TD CLASS="quote"> you'd have to build a custom intake mani to match the tb.</TD></TR></TABLE>
is it really 90mm?
Old Jan 27, 2007 | 03:52 PM
alterdcreations's Avatar
Default Re: 90mm throtle body on H23 vtec? (98vtec)
just take it to a machine shop and tell them that you want them to make a adapter plate . tell them to port match it also.
thats a very big throttle body. i see that they are using them to the k race engines
Old Jan 27, 2007 | 05:54 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">
is it really 90mm?</TD></TR></TABLE>
Yep...I remember XES was going to run one on his boosted Prelude.
Old Jan 27, 2007 | 06:28 PM
nonvteclude's Avatar
Default Re: 90mm throtle body on H23 vtec? (Hawkze_2.3)
that is so big, why would you even need/want a tb that large?
is this in a NA or boosted car?
Old Jan 27, 2007 | 08:17 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Yep...I remember XES was going to run one on his boosted Prelude. </TD></TR></TABLE>
which made what? 500whp?
Old Jan 27, 2007 | 08:27 PM
Hawkze_2.3's Avatar
which made what? 500whp?</TD></TR></TABLE>
I believe so.
For anyone interested--http://www.preluderacing.com
Looks like the old H23-T made 491 hp and his current F20/H22-T makes 400.
Old Feb 6, 2007 | 11:47 PM
Here's a list of his mods. What do you guys think? Some of you will be able to help him out more then i can.
meanshyguy (8:09 PM 2/6/2007): well I'm building an H23 vtec: type s pistons. crower rods. cam gears. type s cams shafts. nology racing wires and spark plugs, cold air intake, RFM Headers, 2.5 inch pipe w/o cat, compression should bump up to 12;1.5 or something like that, I might also get ferrea valves and springs, what do you think, is that good enough for the 90mm throtle body?
Old Feb 7, 2007 | 04:54 AM
benjaminenjamin's Avatar
that TB is overkill like hell, your head and IM arent flowing anywhere near the amount of air that needs a 90mm TB. sell it to someone who needs it, then send your stock TB to http://www.maxbore.com you'll be happy with those results.
Old Feb 10, 2007 | 08:15 PM
meanshyguy's Avatar
Default Re: 90mm throtle body on H23 vtec? (benjaminenjamin)
So what would be the best size, I was thinking of 73 or 74 mm tb. What mods could be made to the IM? and how much needs to be ported, since I'm already working on this.Is there anything cheaper than RMF headers? I want some with a 2.5 inch collector.
Old Feb 10, 2007 | 08:27 PM
vlude99's Avatar
would having a bored TB on a stock H22 help at all or just not worth it? sorry to thread jack
Old Feb 10, 2007 | 08:29 PM
98vtec's Avatar
moderator emeritus
Default Re: (vlude99)
yes.
Old Feb 11, 2007 | 08:41 AM
Attaus's Avatar
Those Q45 TB's are used for a swap on the 7M-GTE's in the MKIII Supra, which are intended for 500+whp.
Old Feb 11, 2007 | 09:05 AM
md23vtec's Avatar
Default Re: (Attaus)
IMO I say that TB is over kill I use a 70mm and works ok for me. 90mm isn't necessary to make over 500 whp. Not saying it will hurt but you defiantly done NEED it
Old Feb 13, 2007 | 05:22 PM
meanshyguy's Avatar
Default Re: (md23vtec)
I'd probably go for 73mm tb. The IM has to be bored accordingly right? any more suggestions concerning air flow?
Old Feb 13, 2007 | 05:26 PM
meanshyguy's Avatar
Default Re: (meanshyguy)
P.S. this thing is for sale ok, I mean the 90mm throtle body, don't get too excited. haha.
Old Feb 20, 2007 | 10:29 AM
peego's Avatar
since you guys was talking about q45 throttle body check this link out http://CUSTOM INTAKE MANIFOLD ...LED
NEW CUSTOM MADE INTAKE MANIFOLD FOR HONDA H-23 MOTOR. PORT MATCHED RUNNERS, STAINLESS NOS NOZZLES, CUSTOMISED 90MM Q45 THROTTLE BODY, CUSTOM THROTTLE CABLE MOUNT, HARD NITROUS AND FUEL LINES WITH NOS FITTINGS. CUSTOM EGR BLOCK-OFF PLATE AND HIGH-PERF FUEL RAIL. ALL COMPONENTS NEW AND NEVER USED
Modified by peego at 11:44 AM 2/20/2007
nightrider93ex
Aug 19, 2016 07:12 PM
blurry454
Jun 24, 2009 10:11 AM
1994PreludeSi
Jan 7, 2007 07:24 AM
BB2H22
Dec 2, 2006 01:36 PM
ApexOne
Sep 1, 2004 06:23 PM
