Want to Buy Want to Trade/Want to Buy
dubya T beeya: sohc header exhaust flange for mani build & high volume fuel pump
Old Jan 27, 2007 | 09:12 AM
digitalcongo's Avatar
Default dubya T beeya: sohc header exhaust flange for mani build & high volume fuel pump
lookin to save a few bucks from the bmcrace price of $30 on the flange...
if you have one...hit me up...
thanx
still sorting out the best way to go for a fuel pump on a boosted d.series...
will be up over 200hp...shooting for 275...
i thought an inline pump would be easy on a loop in the engine bay...
but i wasn't sure if this would work against the stock pump when its on...
not sure how easy the modifications are on an intank pump...
thanx for any pointers
my dude has an intank in his eg to trade...but i wasn't sure how easy it would swap over into the dc2...
info on this would be the best solution...might just go over there and see how far we can get on a swapout...
other stuff i need
Integra TypeR Rear LCA's
emanage ignition & injector harness
oil pressure sender (sender only)
Flexpipe
Local - Custom DP Fab
360-440 Saturated Injectors
d16 rod bearing set
d15 main bearing set
catchcan
Modified by digitalcongo at 2:27 PM 1/27/2007
Old Jan 27, 2007 | 10:30 PM
DelSolDon's Avatar
Default Re: dubya T beeya: sohc header exhaust flange for mani build & high volume fuel pump (digitalcongo)
i don't know if he still has it, but BAM, there you go:
http://ef-honda.com/main/viewt...lange
if you're not a member on ef-honda, he has a D-Series Exhaust Flange for $25 Shipped. you might be able to get in contact with him on eBay, username chaos325
http://myworld.ebay.com/ebaymotors/chaos325
Old Jan 28, 2007 | 03:31 AM
Default Re: dubya T beeya: sohc header exhaust flange for mani build & high volume fuel pump (DelSolDon)
97grnrs
Sep 27, 2007 06:54 AM
Turbo-charged
Mar 10, 2007 05:00 AM
badCRX
Mar 13, 2004 10:28 AM
Screamer
Jun 18, 2003 09:17 AM
