pistons for mini me swap
im building a d15b2 from top to bottom with a d16z6 head, need to know if the d16a6 pistons will work in a b15b2 block? the reason for using these pistons, is because it'll give me a lower compresstion ratio, and i have one laying around, for the turbo build so i can throw more boost to it...
well i need to knwo for sure b4 i buy the parts, well i know the bore is the same, they are both 75mm, but i dont know if the stroke is. i wanna change the rod and piston over from the a6 to the b2, and which bearing do i use if itll work? anyone know?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigwill_2004 »</TD></TR><TR><TD CLASS="quote">well i need to knwo for sure b4 i buy the parts, well i know the bore is the same, they are both 75mm, but i dont know if the stroke is. i wanna change the rod and piston over from the a6 to the b2, and which bearing do i use if itll work? anyone know?</TD></TR></TABLE>
the pistons will work,,but the rods wont...d16 and d15 have different size "big ends" ..so you would need the d16 crank to but it wont work cause the d16 has a higher deck height...
also you should think about forged pistons and rods,,,cause the oem stuff even at a low compression is still very very weak.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">Are you sure the Pistons will work? You would think there are a reason you don't see D16xx pistons marketed along side D15Bx pistons.</TD></TR></TABLE>
Im 100% sure the pistons will fit on his d15b2 rods,,the only thing is i dont know if he knows or not how lower the a6 pistons will sit on his d15b2 rods,,The compression ratio is going to be really low,,like 7.x:1.......So i dont know about this idea unless you plan on running a small turbo like ihi or t3 .48,14b,t25,etc,etc so the fast spool will be there...cause its going to be very laggy with say a t3 .60 or bigger
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigwill_2004 »</TD></TR><TR><TD CLASS="quote">the bore is the same y not?</TD></TR></TABLE> Compression height and wrist pin location.
gurippugasuki
Nov 13, 2006 08:02 PM
