d16z6
Old Jan 27, 2007 | 07:44 AM
efking1985's Avatar
Default d16z6
Ok im doing a d16z6 swap with my 88 tranny i heard that the clutch is different then the 89-91 . im doing the obdo-obd1 ecu conversion so i can use a p28 can i put my 89 si intake manifold on it and still run the ecu
Old Jan 27, 2007 | 07:47 AM
e jay one's Avatar
Default Re: d16z6 (efking1985)
ya the clutch is different. and ya you can use your intake mani with the p28.
Old Jan 27, 2007 | 07:48 AM
efking1985's Avatar
Default Re: d16z6 (e jay one)
i heard somthing like the 88 was 212mm
Old Jan 27, 2007 | 07:52 AM
4speedkamikaze's Avatar
Tjust get another clutch just to be on the save side!!!
Old Jan 27, 2007 | 09:24 AM
dr_latino999's Avatar
Input shafts are different on the 88 compared to 89. On the 88 you have a 21 spline shaft and all the other years you have a 20. Also, the 88 clutch is only 190mm across, 89 is 200, and the rest of the years are 212. If you want a 212mm clutch with the 21 spline input shaft you need to get the clutch from a 1986 - 1989 Acord DX / LX.
Old Jan 27, 2007 | 09:29 AM
Jonknee's Avatar
Since you're not using the obd1 intake manifold with top mount map,you're gonna have to T off a line from the fpr to your map on the firewall to get a vaccum source.
Old Jan 27, 2007 | 09:35 AM
bag's Avatar
bag
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by La-Quiete &raquo;</TD></TR><TR><TD CLASS="quote">Since you're not using the obd1 intake manifold with top mount map,you're gonna have to T off a line from the fpr to your map on the firewall to get a vaccum source.
no he wont,,
he's using his original intake manifold with his original map sensor,so he just leaves it as-is how it came from honda..simple
Old Jan 27, 2007 | 09:38 AM
Default Re: d16z6 (La-Quiete)
</TD></TR></TABLE> You realize a map is a map unless it has a different pressure scale?
Old Jan 27, 2007 | 09:43 AM
Jonknee's Avatar
Default Re: d16z6 (dr_latino999)
For some reasone i blanked out and imagined an obd1 Tb with a obdo map.
HAHAH i need breakfast...
classciv
Jun 22, 2007 08:41 AM
efking1985
Jan 27, 2007 12:34 PM
dkrex001
Oct 23, 2006 06:40 PM
dstudent
Nov 2, 2004 09:06 AM
bigblueandyellow
Oct 21, 2004 06:12 AM
