lost my car keys....no dups....what should i do?
I'm looking for the most cost effective solution, do i need a new egnition? (94 accord) i had a key cutr from the door, but to my surprise, the key didn't work, which means the egnition was replaced one time before i bought the car. not sure what to do.
if the key cut from the door works on everything except the ignition your going to either have to have the ignition rekeyed to match your door key or replace the ignition lock.
not sure about your model, but my car (99) has some kind of electronic sensor in the key.
i had a duplicate made and it works for everything but won't start the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xluben »</TD></TR><TR><TD CLASS="quote">not sure about your model, but my car (99) has some kind of electronic sensor in the key.
i had a duplicate made and it works for everything but won't start the car.</TD></TR></TABLE>
not for 94ish
but again, you are right. 6th gen do sport immobilizer
does it crank? or it would turn at all?
not for 94ish
