Crankshaft pulley bot
Old Jan 26, 2007 | 09:10 PM
baker7598's Avatar
Default Crankshaft pulley bolt
Whats the best way to get this off w/out air tools?
Old Jan 26, 2007 | 09:33 PM
e jay one's Avatar
Default Re: Crankshaft pulley bolt (baker7598)
super breaker bar and the tool to hold the crank pulley and good extensions the kind with lifetime warenty so when they break you get new ones. or you might be lucky and it comes off easy. its always a suprise.
Old Jan 27, 2007 | 07:43 PM
Mavrick's Avatar
Default Re: Crankshaft pulley bolt (e jay one)
put a wrench with a long bar on the crank bolt and turn the engine on, when it rotates it will loosen the bolt a whole lot. Works al the time for me
Old Jan 27, 2007 | 08:38 PM
baker7598's Avatar
Thanks for all the great info. I put a screwdriver in the flywheel and used a 42" breaker bar. Took it right off.
Modified by baker7598 at 11:37 PM 1/27/2007
Old Jan 27, 2007 | 09:59 PM
JokerX-1.6T's Avatar
I gave up today and went and had someone with a impact gun to do it and even than it took them 15 minutes to get it off -
Old Jan 27, 2007 | 10:11 PM
hondasaurusrex's Avatar
Default Re: (JokerX-1.6T)
i just broke 5 craftsman extensions, a craftsman breaker bar, and even tried a 550 ft lb of torque impact with 130 psi behind it and mine still wont budge...dunno what im gonna do, hopefully a dohc ZC swap (Y)
Old Jan 28, 2007 | 08:15 AM
e jay one's Avatar
Default Re: (hondasaurusrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mavrick &raquo;</TD></TR><TR><TD CLASS="quote">put a wrench with a long bar on the crank bolt and turn the engine on, when it rotates it will loosen the bolt a whole lot. Works al the time for me</TD></TR></TABLE>
DONT DO THIS it will turn the bolt the wrong way and break something.
Old Jan 28, 2007 | 08:18 AM
Mavrick's Avatar
Default Re: (e jay one)
duuuhh, when that thing spins it will take out all wires and dent the body real bad. I didn't mean that literally
Old Jan 28, 2007 | 08:24 AM
crxnj's Avatar
Default Re: (Mavrick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one &raquo;</TD></TR><TR><TD CLASS="quote">super breaker bar and the tool to hold the crank pulley and good extensions the kind with lifetime warenty so when they break you get new ones. or you might be lucky and it comes off easy. its always a suprise.</TD></TR></TABLE>
yeah this is what i do all the time..if it absolutely wont come off ill use the little propan torch (i hate using it)
Old Jan 28, 2007 | 09:38 AM
dr_latino999's Avatar
Default Re: Crankshaft pulley bolt (Mavrick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mavrick &raquo;</TD></TR><TR><TD CLASS="quote">put a wrench with a long bar on the crank bolt and turn the engine on, when it rotates it will loosen the bolt a whole lot. Works al the time for me</TD></TR></TABLE> Our engine rotates the wrong way.
Old Jan 28, 2007 | 11:24 AM
Hondacivic90ed's Avatar
"put a wrench with a long bar on the crank bolt and turn the engine on, when it rotates it will loosen the bolt a whole lot. Works al the time for me"
this definately has to be the most dangerous, unintelligent way of removing the crank pulley bolt.
Old Jan 28, 2007 | 11:28 AM
JJ's civic's Avatar
i just took my off about 20 mins ago still putting my water pump on. use a bigg screw driver and put it the flywheel then use a 1/2 wrench with a cheater and then use your foor and push to the back it will work it did for me i broke my 3/8 breaker and my 17mm socket.
Old Jan 28, 2007 | 11:40 AM
projectjazzmine
Jan 20, 2007 08:55 PM
xxmastermindxx
Aug 22, 2006 09:22 PM
jbell
20
Jan 1, 2005 09:09 PM
shauniewalnuts
19
Dec 25, 2004 11:33 AM
Flamenco-T
Jul 8, 2002 05:53 PM
