Anyone use bondo/filler on their rims?
Old Jan 26, 2007 | 08:24 PM
invisible's Avatar
Default Anyone use bondo/filler on their rims?
I seen a few threads about it on other forums, but haven't seen how it holds up. some use for curbs and such.
Old Jan 26, 2007 | 08:25 PM
Stoich EG2's Avatar
Default Re: Anyone use bondo/filler on their rims? (.AMS)
ummmm, i dont imagine it works well with balancing
Old Jan 26, 2007 | 08:26 PM
invisible's Avatar
Default Re: Anyone use bondo/filler on their rims? (Stoich EG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stoich EG2 &raquo;</TD></TR><TR><TD CLASS="quote">ummmm, i dont imagine it works well with balancing</TD></TR></TABLE>
from what i saw there was barley any on there. idunno if its enough to mess with things. http://www.a4mods.com/index.ph....html http://www.autopia-carcare.com/realwhda.html
Old Jan 26, 2007 | 08:47 PM
DOHCVBEP's Avatar
I have seen quick steel used and wheel balancing was not an issue but as for bondo? I have never seen this used to repair wheels.
Old Jan 26, 2007 | 08:51 PM
Stoich EG2's Avatar
Default Re: (DOHCVBEP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .AMS &raquo;</TD></TR><TR><TD CLASS="quote">from what i saw there was barley any on there. idunno if its enough to mess with things. http://www.a4mods.com/index.ph....html http://www.autopia-carcare.com/realwhda.html</TD></TR></TABLE>
that doesnt seem like a bad idea... i might have to try that with my white ITRs
Old Jan 26, 2007 | 08:55 PM
invisible's Avatar
Default Re: (Stoich EG2)
Old Jan 26, 2007 | 10:50 PM
invisible's Avatar
Default Re: (.AMS)
anyone try this here?
Old Jan 27, 2007 | 12:04 AM
2'z kuztoms's Avatar
From: Streets of Sacramento...But now living in So Cal, usa
Default Re: (.AMS)
no. but im sure you will be fine as long as the part where you are going to bondo is sanded to the metal and you dont use too much. as long as you know what you are doing you should be fine. and also use some real primer on bondo. not one of them cheap *** spray can you see at napa or auto zone either. go to your local automotive paint store
Old Jan 27, 2007 | 10:01 AM
invisible's Avatar
Default Re: (2'z custom colors)
thanks
Coreyg
Oct 7, 2007 08:50 AM
tegsallgood
Honda S2000
27
May 28, 2007 08:39 PM
95whitegizzer
Jul 29, 2006 11:28 AM
teamvirus
Jan 10, 2006 01:13 PM
punkhop83
Jan 24, 2005 10:27 PM
