how much to resurface from head? replace valve guides?
Old Jan 26, 2007 | 05:35 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default how much to resurface from head? replace valve guides?
My GSR head is at the machine shop and they told me that the stock surface is perfectly fine from the factory with no warping or dings. how much do you think i need to surface off? precise calculation.
and he said the exhaust valve guides are out of round, do I have to replace them? what are the consequences if i don't?
Old Jan 26, 2007 | 05:43 PM
91SiZ6's Avatar
How much compression do you want out of it?
A resurface is usally as little material as possible. Milling is when you take material off to bump compression. I'd let your machinist do the job you're paying him for.
Old Jan 27, 2007 | 04:46 AM
IntegraType-R's Avatar
0.010 if u just want to keep it almost stock.
Old Jan 27, 2007 | 08:34 AM
Default Re: (91SiZ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SiZ6 &raquo;</TD></TR><TR><TD CLASS="quote">How much compression do you want out of it?
A resurface is usally as little material as possible. Milling is when you take material off to bump compression. I'd let your machinist do the job you're paying him for. </TD></TR></TABLE>
im not looking to mill, i just need the minimum resurface for a new surface.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R &raquo;</TD></TR><TR><TD CLASS="quote">0.010 if u just want to keep it almost stock.</TD></TR></TABLE>
thanks
bump for more opinions. what about the valve guides being "out of round"?
Old Jan 27, 2007 | 12:26 PM
91SiZ6's Avatar
Here's my philosophy. I wouldn't give someone money to do anything to my engine or car unless I trusted their work. If you don't trust your machinist, find one that you do trust.
Taking .010" off is a mill and will bump your compression a tenth or two. A resurface is usually more like .002"-.005". But your machinist said that your mating surface is fine, so why do you want to resurface it? Again, trust the man or find a different one.
Old Jan 27, 2007 | 03:13 PM
Runnerdown's Avatar
^ very true, a resurface is just a skim to ensure good head seal. I have been told many times by my machinist that the ex guides in the b-heads are usually too loose. I replace them.
Old Jan 30, 2007 | 01:31 AM
Default Re: (Runnerdown)
well i decided to have him replace the guides and he said he was going to resurface .005'' off. thanks for all the help
L_K
25
Mar 9, 2007 07:52 AM
AlwayzSpoolin
Jan 17, 2007 05:53 PM
oranginal
Apr 27, 2006 12:52 PM
careawholelot
Sep 11, 2005 12:06 PM
Unsung
Jun 13, 2002 04:07 PM
