help jdm h22 swap
is there a site that sells a book on honda prelude layouts and an answer to every problem on my freaken car. i just bought a jdm h22a and im having so many problems the car revs a 3k rpms when im not even steping on the gas but when i unplug acouple of vacuum hoses it goes down but it sputters and my car overheats
i need a layout of the vacuum lines cuz i think something is not plugged in right.
help i need a prelude tech master or something.
You're not going to get a response with those descriptions.
RECHECK EVERYTHING! What is this JDM H22A installed in? Make sure you plugged in everything to their correct component. I've seen MAP and TPS sensor connectors crossed, they'll cause the car to do something like yours!
Good luck.
Good luck.
its in an h23 si 4th gen car im asuming everthing was connected right but im not getting good results i need a diagram of where everything is supposed to connect so i can check where i went wrong. atleast the car starts its just that something not right.
ok i printed out the diagram and carfully followed every hose in that engine bay and everything is pluged in correctly . so im thinking its something else can it be my TPS or my distibutor maybe my engine is JDM so is there an issue with the distibutor cuz the h23 has an external coil for the 5th plug but the h22 has only 4 plugs and it didnt work but when i pluged in the h22 ecu it worked but i have an extra plug just chilling in my engine bay for that external coil.
